Small screen CA and Grin controller compatibility Q
Ypedal   100 GW
Post by Ypedal » Sep 28 2016 11:08am
Hi guys.. i searched, and have emailed Grin but it's one of those " working on it now, need a quick answer " situations lol.
I have a recent grinfineon 20 amp ( 36 / 48 v) and on the label it says **DO NOT USE WITH SMALL SCREEN CA
Can anyone tell me why this is ? and is there something i can do ?.. i don't need any of the limiting features, just need the power data
This is the two button on the front panel small screen CA if that makes any difference ( vs the older, side, single button )
ES site status page:
teklektik   10 GW
Re: Small screen CA and Grin controller compatibility Q
Post by teklektik » Sep 28 2016 11:42am
Ypedal wrote: I have a recent grinfineon 20 amp ( 36 / 48 v) and on the label it says **DO NOT USE WITH SMALL SCREEN CA
This is because of the changes in the CA-controller interface over the years. Although the connectors are the same, there was/is different assumptions made about the circuitry inside the controller and CA - specifically whether or not a diode was present to allow the CA limiting operation. The older small screen CAs did not have the diode and if connected to a new style controller will result in WOT and immediate runaway (!).
If you only want monitoring capability, simply disconnect the green throttle Override wire (pin 6) from solder pad in the CA or either side of the CA-DP connector.
[The extension bmp has been deactivated and can no longer be displayed.]
If you want limiting to work, you need only add a diode in-line with that wire someplace that's physically convenient. Just about any low power diode will work (1N914, 1N4148, 1N4001, etc). The cathode (little bar marking on the device) should be on the CA side so the diode arrow symbol is pointing towards the CA.
This extra diode will not hinder operation at a later time if you get a newer CA V2, but will prevent operation of a CA V3 - so be mindful of where you add it...
Ypedal   100 GW
Post by Ypedal » Sep 28 2016 11:50am
Fantastic !!!!
Thank you good sir ! 8) 8) 8)
Toorbough ULL-Zeveigh   100 MW
Post by Toorbough ULL-Zeveigh » Sep 28 2016 5:09pm
1N34a?
teklektik   10 GW
Post by teklektik » Sep 28 2016 5:28pm
Sure.
The 1N34A germanium diode looks to have about Ifwd0=50ma, PIV=65V.
We are looking at a 5V throttle voltage and no more than 15ma forward current worst case (very much less typically), so well in spec.
The CA limiting operation will take care of any Vfwd (actually works fine with two diodes in series for setups where the controller had a diode and so did the CA). The low Vfwd of the germanium part is nice but in the end won't really be of material benefit. This is really a high frequency rf part and not my first choice, but use what you've got on hand...
