the12be
- Joined
- Sep 10, 2012
- Messages
- 137
Hi all just thought I would share me and my brother both own 48 volt self make e bike we both over heated them at the same time and we both use 20ah battery's and the same controller (https://em3ev.com/shop/12-fet-irfb4110-em3ev-controller-black/ we decided to re wire them both with 16awg and 30awg silicone wire from (https://www.componentshop.co.uk/cable/silicon-cables.html) very cheap prices anyway I found both motor needed the bearings freeing and new grease adding to both bikes both now run faster with the improvements (before 39 mph - after 45mph)
So to recap the motors are 1000watt with (phase) 16awg silicone wire and (Hall) 30awg silicone wire the cotroller turned up to 60amp constant -120amp peak and the sealed bearing re-greased I would fully recommend this to all
Hope this helps someone
