I just had a thought... as you do.
In my electric bike build, I used a three way XT-60 style connection to the three phase hub motor, to replace the crappy bullet connectors originally supplied.
I can't think of a good reason not to build a shorting plug to go in place of the phase wires coming from the controller, this would effectively make the rear wheel a brake. If you left the bike unattended, and disconnected the controller and inserted the plug, even if theft was attempted by riding away with no power, the rear wheel would literally be a drag?
It certainly doesn't forgo standard anti-theft measures, but worth a go, I can't see any technical reasons not to try it.
