j bjork
I am building an electric bike with a 13s5p battery that is removable. But I am a little concerned that I will get sparks when removing the battery, that will damage connectors and maby controller and bms. The problem is that I don´t have anywhere to easy mount a main circuit breaker.
How big of a problem is it, I will probably remove the battery from time to time?
If I do mount a circuit breaker, will just a 1kohm resistor between the terminals of the breaker be a good way of doing it?
So when the switch is off, there is still connection over the resistor until I unplug the battery.
I want to keep it as user friendly as possible, so that my girlfriend can use the bike. I could have an extra switch for the resistor, but I am worried that it will be too complicated.
