So I am about to purchase my first conversion components and would like another set of eyes to double check I am not missing any items and that I will get reasonable performance. I come from a mechanical background, not as much electrical knowledge. Here is what I am after....
I with these specs in mind, I have decided to go with the TSDZ2 mid drive motor. I plan to update the firmware that casainho and others have been working so hard on. Here is what I plan to purchase (I live in the USA)...
For the firmware upgrade I need the following....
I am trying to avoid needing to wait days after receiving most of the components because I missed something small. Am I missing anything? Are all of these companies reputable? Will I be able to achieve my design specs? I am am least confident in my choice of battery, is this a good choice?
- Rider weight 110lbs (50kg);Height 5'2" (158cm)
- Commute daily; 2.5miles one way (4.0km); 3% Grade for 0.5 mile (0.8km) at the start and then relatively flat
- Would like to be able to occasionally ride 25 miles (some hills, google maps says 300ft of elevation gain)
- Prefer to pedal as opposed to throttle only
- Torque Sensor
- 28mph (45kph)
- Breezer Radar Cafe -- $899
- 52v Tongsheng-TSDZ2 motor kit from recycles-ebike.com --$399
- EM3ev 52V (14S5P) Jumbo Shark Samsung 35E cells - 17.0ah -- 857wh -- (Does this come with a lock?) -- $479 + $84.20s&h
- Not sure which charger...
- EM3ev 2a charger --$30.00 + $6.80s&h
- EM3ev 5a charger with 90/100 switch -- $70.00 + $6.80s&h
- Luna Charger 1a-5a switch with 80/90/100 switch -- $100.00 + $7.00 s&h
- Metal Gear to replace blue gear -- $27.00 + $8.77 s&h
- Already own soldering iron, zip ties, shrink tube
- Is the tool with the motor the same as a Shimano TL-FC32 to remove my bottom bracket or will I need this as well? -- $17.93
- ST-Link V2 -- $5.49
- KT-LCD3 -- $27.40 + $8.77 s&h
- Cable with 4 wires and connector to cut apart and use for flashing TSDZ2 -- $25.00
