Nucular Electronics owner's thread (setup infos, FW updates, links etc.)
warrah   100 W
Re: Nucular Electronics owner's thread (setup infos, FW updates, links etc.)
Post by warrah » May 11 2021 12:48pm
HK12K wrote:
May 07 2021 5:27pm
What connector does Nucular use for the waterproof hall connector on the 24f?
I need to source a couple of motor-side 6p hall connectors, preferably with pigtails, but am having more trouble than anticipated locating them.
I would also like to know this, need to track down some more pins for them so need to know what they are called
PITMIX   1 kW
Post by PITMIX » May 11 2021 1:43pm
It is a universal connector as on Sabvoton, Votol controllers.
Aixam 550 Twin retrofit Qs 138 70H, Nuc 24F, LG 20s 60Ah
https://cyclurba.fr/forum/621300/nNlect ... #msg621300
Yamaha TDR 125 retrofit Qs 138 90H, Nuc 24F, LG 20s 60Ah
https://cyclurba.fr/forum/714639/retrof ... #msg714639
Keeway City 50 retrofit Qs 120 70H, Nuc 12F. LG 20s 30Ah
https://cyclurba.fr/forum/698717/e-scoo ... &pageprec=
warrah   100 W
Post by warrah » May 11 2021 2:06pm
PITMIX wrote:
May 11 2021 1:43pm
Yeah I've noticed that too, they show up all over the place, just not on Google when you want to buy more. If anyone knows what the connector industry calls them, do let us know. By the way pitmix I love your car!
PITMIX   1 kW
Post by PITMIX » May 11 2021 2:11pm
HK12K   100 kW
Post by HK12K » May 15 2021 11:12pm
PITMIX wrote:
May 11 2021 2:11pm
This is for CDI socket
https://www.lazada.com.my/products/mode ... 90905.html
Thank you. 8)
litespeed   1 MW
Post by litespeed » May 22 2021 10:10am
So has anyone here successfully hooked up the uLight using a DC to DC converter to 12 volts for head, tail & brake lights with blinkers/hazards? I have a few issues that I just can not figure out…..I don’t want to guess. So to start with what converter did you use? Then, how do you switch it off and on? Using a relay or high voltage switch? Vasiliy recommended using an isolated dc/dc so it won’t blow the controller so the one I bought will not work. Problem is I can find a isolated dc/dc that has a remote switch lead so I can turn it off/on with a key switch. Also, I find the wiring diagram confusing and doesn’t show how to wire the dc/dc supply in!
I’d appreciate any help you could offer.
Thanks
Tom
Battosaii   10 mW
Post by Battosaii » May 30 2021 11:45am
PITMIX wrote:
May 01 2021 3:17pm
Battosaii wrote:
Apr 21 2021 9:41am
This is the thumb throttle I'm using. I've been at this for hours. I have two of the same throttle. I'm at the point where I'm starting to think the throttles are incompatible or they are just broken idk. I just want to ride my bike lol.
Did you learn the throttle?
That didn't work at the time. They were bad throttles, the replacements I got work perfect, although I may go to full twist throttle now cause the thumb throttle gives my hand cramps after hours of riding.
bigbore   10 kW
Post by bigbore » Jun 07 2021 8:23am
Has anyone already installed an electric scooter alarm with a Nucular controller?
Looking at the diagrams available online it seems that these alarms have a direct connection to the battery voltage with the black and red two-wire connector. Through the other 3-wire connector they can:
- Activate the controller
- Block the rotation of the motor
- Feel the rotation of the motor
From this diagram it seems that the wire for the recognition of the motor rotation can be connected directly to a phase wire.
E-scooter alarm diagram.JPG (37.66 KiB) Viewed 1181 times
Bomber replacement chain, Saltplus WARLOCK half link BMX chain 1/2" X 1/8" catena BMX :
https://endless-sphere.com/forums/view ... 7#p1667017
Bomber V-Boxx output shaft sprocket:
viewtopic.php?f=31&t=114027#p1686112
cheeko   100 W
Post by cheeko » Jun 13 2021 8:06pm
If you have Ignition wired up, will that overright the screen button on back to turn on.
Anyupdate on BMS?
Cheers
Guys
20S7P Futr Beta 26" Mxus3k with the Unbelievable Nucular 12F
bigbore   10 kW
Post by bigbore » Jun 14 2021 3:21am
cheeko wrote:
Jun 13 2021 8:06pm
Anyupdate on BMS?
Cheers
Guys
That sounds good.
Now there are the other 2 things to sort out that maybe are more complicated becasue the controller sould be switched off when doing:
-Motor rotation detection
-Motor rotation block
cheeko   100 W
Post by cheeko » Jun 17 2021 7:51pm
bigbore wrote:
Jun 14 2021 3:21am
cheeko wrote:
Jun 13 2021 8:06pm
Anyupdate on BMS?
Cheers
Guys
That sounds good.
Well im going to wire up inigtion on the weekend and see what it does, as i plan to not turn off my BMS let it go to sleep so i can just use my Igition switch for Nucular, When i one day leave it somewhere ill turn off BMS, Which most people wont know how to turn on as i have hidden Momentary Switch.
At mement i turn off my BMS and it resets my Battery level every time i guess becuase im totally dropping power to controller.
cheeko   100 W
Post by cheeko » Jun 17 2021 7:54pm
Also anyone know what settings they use for Dimonio throttle, seems after i did update i needed to put up the min voltage or it will spin seems pretty high then it was for min voltage.
Cheers
Dung   10 mW
Post by Dung » Jun 18 2021 5:46pm
PITMIX wrote:
Mar 16 2021 12:47am
cheeko wrote:
Mar 15 2021 9:37pm
Hi Team
I recently upgraded to the lastest firmware and i notice there is alot of extra features, Now 2 mins before i updated my Switch brake was working fine montrary switch connected to the screen. Now after upgrade it no longer works is there a setting i have missed
Any ideas as i dont think it stopped working as bike hasnt moved and was working right before i upgraded.
Its montary button to screen so pretty simple, maybe there is a setting to trigger etc
Thanks again for your time.
Cheers
Look at this. I show how to program the buttons on the screen but you can also program the inputs last screen yes on the controller in the same way.
https://youtu.be/7KvbdhWueUQ
Hi PITMIX
I follow your video guide, but when I'm on "Display Buttons" I dont see CAN Buttons. The the options (buttons or switch) I got is: USB Charger - Cruise - Speed Mode Cycle - Speed Mode 2 - Speed Mode 3 - Add. Brake - Reverse.
cheeko   100 W
Post by cheeko » Jun 22 2021 11:41pm
Is it possible to downgrade firmware in screen and controller from lastest one?
cheeko   100 W
Post by cheeko » Jun 23 2021 5:44am
VasiliSk wrote:
Jun 23 2021 3:12am
yes just not below originally installed
Thats ok as i really cant work out the brake on IO8 but it was working fine before i updated, Stopped as soon as i uploaded new config, iv checked multiple switches all i can think of the issue.
My setup was one of the first versions
VasiliSk   1 kW
Post by VasiliSk » Jun 23 2021 5:46am
in display port should be set to 'switch' and CAN x
in controller ports CAN x set to BK
disable unused ports in controller
bigbore   10 kW
Post by bigbore » Jun 23 2021 7:14am
cheeko wrote:
Jun 17 2021 7:54pm
Cheers
I made the auto-setup 2 days ago and my Domino is working in the right way but I had a 100ohm resistore between + and - of the throttle pot from my previous Adaptto setup.
cheeko wrote:
Jun 17 2021 7:51pm
bigbore wrote:
Jun 14 2021 3:21am
cheeko wrote:
Jun 13 2021 8:06pm
Anyupdate on BMS?
Cheers
Guys
That sounds good.
Are you talking about the key switch or the wire from the alarm that would activate the controller?
cheeko   100 W
Post by cheeko » Jun 23 2021 7:58am
VasiliSk wrote:
Jun 23 2021 5:46am
Thanks Vasili i wasnt doing it on the display port correct.
cheeko   100 W
Post by cheeko » Jun 23 2021 7:59am
bigbore wrote:
Jun 23 2021 7:14am
cheeko wrote:
Jun 17 2021 7:54pm
Cheers
cheeko wrote:
Jun 17 2021 7:51pm
bigbore wrote:
Jun 14 2021 3:21am
cheeko wrote:
Jun 13 2021 8:06pm
Anyupdate on BMS?
Cheers
Guys
That sounds good.
Yes i think ill try resistore see if that helps,
cheeko   100 W
Post by cheeko » Jun 23 2021 8:08am
[/quote]
Yes just want to wire key up to controller only turn on with key, I guess this is the Remote Port and have K1 and GND to short on Switch
Then in display set it to switch.
Ill try this tomorrow.
Thanks for your help guys
bigbore   10 kW
Post by bigbore » Jun 23 2021 9:13am
cheeko wrote:
Jun 23 2021 8:08am
[/quote]
Have a look on telegram assistance chat I had some info about the key switch and under display button
Dung   10 mW
Post by Dung » Jun 27 2021 5:30pm
VasiliSk wrote:
Jun 19 2021 12:48am
I guess you need to update controller and display
Thx for the fast reply. You right I forgot to update the display. It works now.
cheeko   100 W
Post by cheeko » Jun 28 2021 10:51pm
bigbore wrote:
Jun 23 2021 9:13am
cheeko wrote:
Jun 23 2021 8:08am
[/quote]
I gave up ill just stick to my turn BMS off LOL
