I am using an unlocked Sabvoton SVMC72150 with a MXUS 3k 3T. I guess the throttle is controlling the phase amps.
I am using 350amps max. phase amps. When near top speed with flux weakening disabled (around 55mph) only about 1/8 of the throttle is usable (15% throttle has the same effect as full throttle), because the motor can only pull around 50 battery amps (and maybe around 60 phase amps).
I dont think there is a way to change this, is there?
I am using 3V and 170amps as medium throttle values.
Another problem is when riding offroad in a low speed section or steep uphill, the throttle should be much less sensitive.
Is there anyway to add something like a low speed mode to the throttle (so throttle voltage seen by the controller would be for example 1.2-1.6V instead of 1.2-5.0V in this mode)
The low speed mode of the Sabvoton I think only limits rpm, but does not limit phase amps.
