I might have been compose a little confused. I put like BMS on the 36V battery pack:https://www.aliexpress.com/item/10S-36V-16A-25A-35A-45A-60A-BMS-PCM-PCB-for-18650-Lithium-Ion-Battery-Pack/32950870605.html?spm=a2g0s.9042311.0.0.27424c4dekZQir
The 11S BMS is more expensiv(https://www.aliexpress.com/item/11S-Lithium-Ion-Battery-samrt-BMS-with-Bluetooth-Communication-APP-software-pcb-board-with-20A-to/32951017667.html?spm=2114.search0104.3.78.1a0e5660seBIYI&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_319_10059_10884_317_10887_10696_321_322_453_10084_454_10083_10103_10618_10304_10307_10820_10301_10821_537_536_10902,searchweb201603_16,ppcSwitch_0&algo_expid=11c8c5f8-9301-4479-8259-c95d87789cc0-11&algo_pvid=11c8c5f8-9301-4479-8259-c95d87789cc0&transAbTest=ae803_5)
And this battery pack does not work with the BMS from 11S BionX battery.The display(G2) shows an empty battery and disables the run motor.The version number of 11S BionX BMS is also 5,1 like the 10S BionX BMS.
Why doesn't it work with the 36 Volt Battery? Is your software programmed to work with only the 39.6 Volt battery? Can I change this by some device? Thank you
