Mathurin said:
A thought on hub stress.
Because of the way a wheel is dished, the ds spokes get more stress then nds. You can feel this easely just by grabbing a wheel and feeling the spokes. I used to wonder why on high end wheels the nds is radial and the ds is crossed, I would have thought doing it the other way around would transfer stress on the less stressed nds spokes, and so make a wheel that lasts longer.
Because of the torsional windup of the hub when drive is applied to the sprocket, up to 90% of the drive is applied to the ds spoles. Radial spoking provides no resistance to the wind-on of the hub in relation to the rim. Only the tension of the spokes resist this after a small amount of wind-on, placing enormous pressures on the nipple seats and hub flange, causing failure of the rim, or failure of the hub due to the tension being applied through the narrowest section of aluminium in the flange.
Crossed spoking (the more crosses the better) is not effected by this as there is minimal hub wind-on, the pull on the nipple seats is not amplified and the spoke tension is pulling through a larger section of aluminium in the flange.
With those high end wheels, crossed spoking in the ds will take nearly 100% of the drive, the torsional wind-up of the hub and zero drive effect of radial spoking will mean little going through to the nds.
With the suggestion of reversing this and having radial spoking on the ds, another aspect comes in. Ds spokes are tensioned to 2-3 times the tension of nds spokes.This problem got worse with the increasing cog count on clusters. Due to the fact that most drive will have to be transmitted through the hub to the crossed nds, there will be a lot of hub wind-on on the ds due to the radial spoking. This will definitely cause a failure of the ds hub flange or the nipples will pull through at the rim. It is only a matter time for what happens first.
Offset spoke holes in the rim help to alleviate the difference in tensions by making the inclining spoke planes closer to equilateral.
Mathurin said:
It seems they don't do that because it fatigues hubs and tends to make them break. Using a beefier hub would add weight, but it seems it's less heavy to use crossed lacing on ds using brass nipples and sometimes beefier spokes, and on nds radial lacing with alu nipples and sometimes thinner spokes.
Radial spoking is largely a cosmetic thing. One argument is that a smaller frontal area is exposed because of it being shorter, causing less drag. This would probably be immeasurable though. I reckon most do it to be different and it looks neat. I did.
The fact that a 3 cross pattern is by far the most common used is no accident. For any given materials, it provides the most cost-effective strongest wheel possible. 4 cross is heavier, runs the risk of spokes interfering with each other at the flange and is harder to build. 2 cross may not be used because it runs closer to the edge of the envelope as does 1 cross and radial. These work in high end wheels because they are built with better materials.
Imagine trying to build a wheel with mild steel spokes in a pressed flange in a cheap rim and make a profit. You'd go for the cheapest, quickest, strongest method.
I run 2 cross and radial on the rear wheel and radial on the front wheel of my Audax bike. I find that I have to regularly re-true the front wheel and occassionally the rear. I don't think it's because of my lousy wheelbuilding skills
but due to the inherent lack of strength with radial spoking. There is more unloading of the tension of the spoke from sharp bumps and even the slightest amount of spoke twist unable to be removed in truing can come out.
According to tests by Jobst Brandt (and in my own experience) the strongest, most resilient wheel has 3 cross laying, double-butted SS spokes in a dual wall rim with eyelets.
Note the "resilent". A deep V rim will be stronger, but is a damned uncomfortable thing to ride.
