I want to build a little throttle smoother using an Arduino. I've seen online that most controllers won't accept the PWM output from the Arduino and it needs to be converted back to analog using an RC filter.
Can anyone recommend a resistor Ohm value and capacitor Farad value to use that give a good response time and not too much wiggle in the final voltage output? It's going to be used with a cyclone controller if that makes a difference
