cal3thousand said:
You haven't answered my question of whether or not you have tried the charger in a working socket other than the generator.
The post right above yours seems to:
bakaneko said:
The charger works in a wall socket where the breaker box can accept this type of Japanese Type A and the charger works plugged in both ways.
and a previous post
bakaneko said:
the charger works in a wall socket because the breaker box connected to that socket is grounded.
What I would guess (without knowing what hte rattling inside the charger is) is that the generator output is not clean enough for the charger that doesn't work on it, and the one that does work on it is just more tolerant.
Guessing on the rattling (since no investigation has been done) is a blown cap, which could cause the intolerance problem. But it could be any kind of damage or loose parts shorting things out, causing all sorts of havoc in there.
I have no idea why people think it's safe to use electrical stuff with known faults inside (that they don't know the cause of) that could cause fires, but it is apparently very common. :/
bakaneko said:
okay, tell me if this make sense. so the charger has a type B plug without the ground pin. the two blade pins are live and the generator is not grounded (has a ground pin not connected). so therefore, the charger will not work. the charger works in a wall socket because the breaker box connected to that socket is grounded. and, my two prong type A dremel works in the generator because the larger blade on that plug is a ground and smaller is live.
No.
Regarding the two vs three prong: It doesn't matter. If a device works on the wall socket it'd work on the generator. Grounding has nothing to do with it. None of the current should ever flow thru ground, it is only there for safety. If current does flow thru ground with a two-prong device plugged in, then the socket is miswired.
Two prongs use only line and neutral, and require the casing of the device be specifically insulated from all of the interior electrical connections (because there is no ground to hook to the case to redirect any internal shorts of the case to interior electrical connections). Most things using two prong connections have plastic cases, and those that don't usually have at least two forms or layers of insulation between the case and elecrical stuff inside.
The type with two narrow prongs is "universal" and does not have a specific Line and Neutral; they are interchangeable inside in the electronics.
The type with one narrow and one wide does have a specific Line and Neutral, sometimes because of the way the interior insulation works, and sometimes because of the electronics, and sometimes just because that's a common enough plug type that it is cheaper so they used that kind.
