casainho
10 GW
- Joined
- Feb 14, 2011
- Messages
- 6,045
Try to reset the display configurations, please report if it qorks or not.soblik said:Hello to all TSDZ2 fans.
1. I changed the display to Bafang 860c, I uploaded the software to the display (1.1.0) and engine (1.1.1), everything works fine except for one thing. I have a temperature sensor installed in the engine and when it activates in the options in the 860c, it shows the correct temperature, but interestingly, the engine does not support. The temperature is not exceeded in terms of the temperature range. What could be the reason? Everything worked on the old KT LCD3, so I conclude that something needs to be changed in the 860c settings.
Ad 1. solution: poor connection between sensor and controller
2. I performed the pressure sensor measurements according to the available guide on the OS project website for TSDZ2. In the 860c settings, I set the calibration to "on" and set the ADC values and weight according to the thin lines plotted on the graphs below. But why after calibration, when I put, for example, 10 kg on the pedal, I still read the value from before the calibration, and not the new one that I set? Is this the correct symptom or am I doing something wrong?
Thanks for any suggestions.
The ADC value of torque sensor is the raw value. What is changed with the calibration is the calculates approximated value of weight on the pedals.
