Hi All,
I have a problem with a BBS02 mid drive, 350W 36V. The motor suddenly cuts out, then back in within say 1/4 of a second. It's like the power to only the motor was turned off then back on, power returning with an audible clunk through the internal gears. It's not like the power interruption from brake switches or gear sensor where the motor smoothly stops and restarts - this is sudden.
It happens with brake & gear sensors connected or not, and with the BBS unit swapped to a different bike and battery. It does it under load and no-load.
When it does cut, it is always with the cranks at a particular angle, but it doesn't do it every crank rotation...
The BBS unit has been back to the retailer who could not fault it but still changed some internal components as an attempt to fix it. (incidentally, based on a video of the problem they agree it has an issue, but can't replicate it.) The retailer's sending me a new unit, but I'd really rather like to know what might have been the problem.
Any thoughts at all?
