Hi friends, I have two batteries for my new bike — 48V, 17A Samsung. They don’t run in parallel, only one at a time. Both have the same problem. When they get under 50% on the display, they suddenly start to drop ten or fifteen percentage points at a time, then from 15% or so right to 0%, then, while still putting out low power, the display shows the battery jump back up to 4% or 8% ish. After that the battery might still put out low power for a long time. It might put out low power for an hour while showing 0%, or for an hour while showing 4% the whole time. The bottom line is that I can’t count on these batteries once they get under 50%.
I’ve been trying to fully cycle the batteries and let them stay on the charger for awhile when full. I’ve done that three or four times with each battery and had no improvement. I can’t find beginner’s battery balancing instructions on the web or elsewhere on this site. Can anyone help? Thanks so much!
