Backstory: I'm moving to Germany, where my current eBike setup is illegal. I want to get a BBS01 and fit it with the 500W BBS02 rotor and stator as others have done in order to bring the cadence to something more comfortable (>95 RPMs).
https://www.pedelecs.co.uk/forum/threads/bafang-bbs01-changing-rpm.34027/
For the cadence specs (below) for the 500W BBS02 at 36V and 48V, are those measurements taken at that actual voltage, or, for the 36V spec, are they taken with a "full battery" assuming something like 10S @ 4.2V = 42V or 10S @ 4.0V = 40V?
I'm looking at LiFePo4 packs that Tumich currently has for sale that run at 34V.
If "36V" is truly measured at 36.0VDC, the quoted 113rpm run at 34V, which is 113 * (34/36) = 107rpm is a completely fine cadence to me. But if "36V" is measured at 10S @ 4.2V = 42V, then running at 34V is 113 * (34/42) = 91rpm is on a the low side for a no-load motor speed.
Anybody have insight?
Or would somebody with a 36V 500W BBS02 measure their no-load speed at a specific voltage so that I know rpm/V for this motor?
Thanks in advance.
Thanks in advance.
