Best grease for CYCLONE gearbox.
sviatpizdat   1 mW
Post by sviatpizdat » Oct 13 2020 11:50pm
Hello, friends! What grease are you recommend to use in gearbox ? I have metal gears. (cyclone mini 1680w)
electric_nz   100 W
Re: Best grease for CYCLONE gearbox.
Post by electric_nz » Oct 14 2020 1:23am
I have literally just bought a tube of mobilith shc 100 to pack into a cyclone 1680 that I’m rebuilding. Will report back.
It had slowed down a bit and was getting noisy so I did a tear down, found the old gear teeth had worn to sharp points and the old grease had turned into glue.
I’ve replaced the planet bearings and metal gears (which I’ve lightly sanded to remove any burrs) and will be reassembling within the next week or so.
The motor feels awesomely solid and well built, everything fits snugly and the motor part looks brand new despite 1000s of km...
aCeMadMod   1 kW
Post by aCeMadMod » Oct 14 2020 3:46am
Don't use gesse..use oil mod it...
DtiK   1 W
1 W
Post by DtiK » Oct 14 2020 10:03am
has anyone installed grease nipple?
sviatpizdat   1 mW
Post by sviatpizdat » Oct 15 2020 1:03am
aCeMadMod wrote:
Oct 14 2020 3:46am
Really? What oil you recommend?
Is oil not too muth liquid?
Balmorhea   1 MW
Post by Balmorhea » Oct 15 2020 1:49am
sviatpizdat wrote:
Oct 13 2020 11:50pm
Me? I'd use CV joint lube.
___________
Finish Reconstruction.
sviatpizdat   1 mW
Post by sviatpizdat » Oct 16 2020 1:32am
electric_nz wrote:
Oct 14 2020 1:23am
Which bearings are used in gearbox?(type, size?)
You ordered new metal gears from Taiwan?
electric_nz   100 W
Post by electric_nz » Oct 16 2020 5:25pm
Plain old 608z shielded bearings picked them up locally for a few dollars each. Gears can be bought from cyclone-tw site, Paco will combine shipping if you buy a few items.
electric_nz   100 W
Post by electric_nz » Oct 19 2020 1:15am
Ok so I think I’ve found why these things are so noisy.
They have 3 planetary gears which sit between two steel plates. The bearings are fixed by spacers but the gears are ‘floating’ on the bearing outers, and can rub on the planet carrier and/or output shaft carrier which I suspect causes a lot of the noise. I’ve done the old mechanic trick of putting a few centre punch marks on the internal bore of the gears so they need to be pressed on to the bearings; and with a little tweaking they are now fixed on the bearings with a decent gap between the gears and the carrier plates.
Now to reassemble!
https://mrbill.homeip.net/albums/cyclon ... es/l42.jpg
sviatpizdat   1 mW
Post by sviatpizdat » Oct 19 2020 10:12am
electric_nz wrote:
Oct 14 2020 1:23am
Hello!
Why mobilith shc 100 instead of shc 220 ? shc220 has more suitable speed and temperature parameters.
electric_nz   100 W
Post by electric_nz » Nov 06 2020 2:24am
Well an update on this, with new grease planet gears and bearings the motor is certainly not much if any quieter, although there is less discordant screeching and more of just a high pitched gear whine, which is tolerable. Subtle it is not- sounds like a formula one car.
Feels much the same power wise although didn’t get much of a ride due to chain issues and battery charger dying.
Hope to bed it in over the next few weeks and see if it quietens down any more as the gears and grease settle a bit.
aCeMadMod   1 kW
Post by aCeMadMod » Nov 06 2020 5:15am
u sould have mod my it betterr then a belt 3220 in sounds no power
hard gaers and change them you can"t hear me over stock 0nes
BeachRider2016   100 W
Post by BeachRider2016 » Jan 05 2021 10:50am
aCeMadMod wrote:
Oct 14 2020 3:46am
Just pour atf oil and plug up the vent screw hole?
My Ebike with chinese frame: viewtopic.php?t=83275
2nd Stealth clone ebb w/3k hub laced 19” dirt rim/tires
2 Walmart special dk duke fatties bbshd and the other w/1k rear hub motor
Full suspension fatty/AliExpress frame w/bbshd
29er hard tail w/tsdz 500w dyi programmed
Intense uzzi slx w/1600w mini cyclone
Trident fat trike 26” w/tsdz 500w diy programmed
Carbon fat bike Bafang ultra, DengfuE06 frame viewtopic.php?f=6&t=109970
Post by BeachRider2016 » Jan 07 2021 9:32pm
I did just that, filled through the vent hole with a syringe with cvt fluid and plugged up the holes with screws. Took about 200ml. I did open the gear box and clean out as much grease as I could with a towel before adding oil.
After a few hard runs I noticed the noise has quiet down ALOT. No more loud screeching noise, but still a lot louder than bbshd, or tsdz.
I’d say oil bath is a success. Now if we can find some nylon gears then it’ll be even quieter.
aCeMadMod   1 kW
Post by aCeMadMod » Jan 10 2021 5:06am
nylon gears only way take down the sound
for 1680 watt motor
i use 2 nylon gears 1 steel one
cyclone dose not sell them i got from a other users here
HY10   10 mW
Post by HY10 » Jan 10 2021 5:27pm
aCeMadMod wrote:
Jan 10 2021 5:06am
for 1680 watt motor
Hi all
Is the atf oil ok for nylon
Are the nylon gears still available
AFT 1680
bbs hd
G510
LeftieBiker   100 kW
Post by LeftieBiker » Jan 10 2021 5:56pm
Don't be too shocked if you can't eliminate a substantial amount of noise, as it's the main drawback to planetary setups - aside from taking up space and weighing more! My Vectrix sounds like a banshee, and lots of people have tried to fix that with their VX-1s, and failed.
Post by BeachRider2016 » Jan 11 2021 11:09pm
Wonder what the dimensions are? I’ve seen a lot of planetary gears on AliExpress in nylon in various dimensions.
aCeMadMod wrote:
Jan 10 2021 5:06am
for 1680 watt motor
PopTart   1 mW
Post by PopTart » Apr 27 2021 12:03pm
Does this ATF oil mod really work? I'm curious to try it. Just fill the thing all the way to the top?
neptronix   100 GW
Post by neptronix » Apr 27 2021 12:33pm
LeftieBiker wrote:
Jan 10 2021 5:56pm
Protip: noise insulation works best on higher frequency sounds. So with very little of it, you could quiet a drive like this down.
Mobilgrease 28 may be ideal for this motor. It's recommended for use in geared motors with nylon gears, but should work fine with a metal geared application.
fechter   100 GW
Post by fechter » Apr 27 2021 2:11pm
Another thing to consider is chainsaw bar and chain lube. I have a Bafang Ultra that melted its plastic gear and I installed a metal one. Not having any suitable grease, I tried the chain bar oil. This oil resembles motor oil, but has additives that make it stick to the metal and not fling off at speed. It worked well in the Ultra but I still had an anointing noise from one of the freewheel clutches every time I stopped pedaling. At some point after about 6 months and several hundred miles I took it apart and found the gears still looked wet with oil. I wanted it to be quieter and packed the gears with some grease. This made it immediately louder! Eventually I will take it apart again, clean off the grease and go back to the chainsaw oil.
aCeMadMod   1 kW
Post by aCeMadMod » May 01 2021 2:02am
no sound can be done. with alot of works i done it
best of good luck for others :shock:
