Hello, there is something a little unclear about the Ultra torque sensor calibration.
It seems that with no pressure on pedals, base input voltage is around 750 mV (TqVoltate)
Said that, it looks like default torque settings have no sense at all.
Infact, default do not take care of the sensor base voltage, that is around 750 mV.
If I well understood, with defaults is like to press 18,75 kg as you move the pedals with minimum force.
This can mean too much power at wheel when start pedaling.
Michael's Frey well studied this fact, you can read his conclusions and "smooth settings" at this link:
http://frey-bafang.patransformers.com/2020/10/09/bafang-ultra-programming/
You can compare the two sensor calibration settings, where Michael correct Bafang mistake:
But you can better see the difference with the 2 conversion curves comparing:
What you do think about all these calibration curves ?
Regards
Regards
