Phaserunner V3 over voltage on 52V while autotuning BBSHD
VRMinde
100 µW
Hi,
phaserunner v3, no CA connected yet.
Trying to setup and autotune my BBSHD, static test passes and on the spinning test I get error 12 - Instantaneous controller over voltage.
Battery pack 14s5p charged to 52V.
Everything worked flawlessly with the stock controller before installing the PR.
ATTACH]
ATTACH]
Where should I start looking for the problem? Thanks
I did autotune with another 12s pack with no issues... I will examine the 14s pack and report back if I find an issue :shock:
My 14S pack ir now charged to 52V, I used 3 different devices to confirm the voltage... I can't figure out why do I get the overvoltage error, phaserunner supposed to work with up to 96V.
