Is there any advantage to 72v?
amwildman
Im ready to start building my battery pack. Bike is a basic hybrid bike ( road bike with some mountain bike traits). No shocks front or back. Motor is GNG cyclone clone with their included controller (cheap). I only intend to go maybe 15-20 mph, but would like a little reserve power. I dont want to be running at max all the time. Mainly leisure riding around town, slight hills.
Is there any advantage at all in running a 72v battery? Would i be better off sticking to 48/52 and putting the extra cells in parallel?
Higher V is always better
not just for higher speed
but getting high torque when needed at lower amps.
Swapping out the controller is much easier / more likely than changing the battery voltage.
But then if the simulator shows even 36V is enough for your desired top speed
you could build two sub-packs and actually A/B test it for yourself
48 volts is plenty for your needs. Also cheaper.
All else being equal, but there are a fixed total number of cells in this case, so higher voltage = lower current.
OP, most properly you'd model your entire system to answer quantitatively, but your requirements are modest enough that a safer, cheaper, widely-available <60V max pack would be desirable.
