Hi Chalo, thank you for your time and reply, a front hub motor would be ideal as i get to keep the gears and the weight would be more even but i want a small geared 750w + motor for the sleeper look plus speed but i cant find one, i dont want to pay for a large front ungeared hub when i already have a 1000w ungeared rear motor. You are right about the mid drive i think, if i change the gearing so its more usable then i fear the 8 speed hubs life maybe limited, plus i hardly ever pedal on my 1000w bike as i have a throttle, the bike came with a 8 speed hub with a drum brake with no lugs/mounts for v brakes and the eyelet is to high (80mm+ drop) to fit a normal side pull brake so a disc brake is my only option if i fit the rear hub motor.
So i think i have decided, mid drive with the 8 speed hub is risky plus £320+ without a battery is a lot for this beast.
Front hub yes, but cant find the right one.
So im going for the rear 1000w hub i have, with the disc brake and the torque bar it might look a bit messy but the chain guard will hide the motor a tad at least, i will lace the rim with 13g spokes and then will sell the hub on ebay, they go for around £100 ish which is nice as that's more then i paid for the bike
Thank you again for your input and advice Sir.
Here is the motor/battery and stuff i will use i think.
https://www.ebay.co.uk/itm/402568582305?hash=item5dbaf514a1:g:tu0AAOSwTahft5Eu
https://www.ebay.co.uk/itm/313316598015?hash=item48f31fe0ff:g:qiYAAOSwHeVfvpM1
https://www.ebay.co.uk/itm/154367545665?_trkparms=aid%3D1110002%26algo%3DSPLICE.SOI%26ao%3D1%26asc%3D20201210111451%26meid%3D087180356ee34e28ba3f6cfe7e214eaf%26pid%3D101196%26rk%3D1%26rkt%3D12%26mehot%3Dpf%26sd%3D152868563680%26itm%3D154367545665%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DPromotedSellersOtherItemsV2WithMLRv3&_trksid=p2047675.c101196.m2219
https://www.ebay.co.uk/itm/264208426727?chn=ps&var=564528375722&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=564528375722_264208426727&targetid=1139674279347&device=c&mktype=pla&googleloc=1006907&poi=&campaignid=12125450102&mkgroupid=116380011106&rlsatarget=pla-1139674279347&abcId=9300480&merchantid=7213384&gclid=EAIaIQobChMIrPnhoIbF8AIVVeJ3Ch1kgA25EAQYASABEgL_PfD_BwE
P.s this my ebay shop thing https://www.ebay.co.uk/usr/jtur5411
the Dawes bike i will be selling soon i think.
