I have ordered a BBSHD with all accessories (programming cable) and I want to run it with a high current 36V battery pack (2 times 5S).
I already tested and it seems to work fine in the first tests. However I noticed that the programming software is quite limited. The lowest Low Battery Protect Value is 37V which is higher than the nominal voltage of my battery.
I noticed that it is possible to programm the whole firmware.
Is there a way or a mod to lower the Low Battery Protect Voltage?
I would like to set it to about 32V or 33V.
I noticed that the "STC-ISP" programming tool has a field that is called:
Low Voltage reset - LVD detect level
and the values are very low at about 2.63V
Can I edit this value to overrule the setting in the szbaf config tool?
