PeteCress
TSDZ2 mounted on a ICE Adventure HD tadpole trike running through a Rohloff 14-speed hub.
Trike + rider = 308#.
No throttle connected, PedElec only.
Used mainly to help on hills and against headwinds once I start to feel like I am "Grinding".
Typical range w/that use on a "52V 14AH... 40 amps output....over 700 watt hours... Samsung 35E high capacity 3500mah cells....INR (lithium nickel manganese) chemistry..." battery is 30-40 miles w/battery kept w/in 20-80% capacity.
Capped at 400 watts, but 95% of use is below 250 watts. More watts when I am in a situation where I need maximum speed for a short period.
Is this "Heavy", "Medium", or "Light" use"
I am trying to dope out a preventive maintenance schedule.
Right now, I am going with:
- Re-grease main gears (but not the blue plastic gear) every 500 miles w/Mobile 28.
- Pre-emptive replacement of blue plastic gear + grease same w/Mobil 2 every 1,000 miles.
- (Pre-emptive Sprague Clutch replacement? I have no clue)
