BBS02 Pedal in reverse to charge battery?
Hey, I'm making a special project and was planning on using a bbso2 to charge the battery on a nonmechanical dual hub drive bike. Initially, I was going to weld the freewheel apparatus but it seems like pedaling in reverse turns the rotor and should produce a charge. If this is the case I can definitely just mount the motor on the opposite side.
Before I start doing some tests has anyone done this?
Please clarify your use case more.
Do you mean regen while traveling?
Or stationary, use as a generator only?
What is the overall big picture? motivation etc
