Dragos
- Joined
- Apr 2, 2021
- Messages
- 10
Hi,
just got a new motor from pswpower and opened it to do all the mods I have done on my first purchased TSDZ2 (older version, where the main gear had only one one-way bearing).
This motor has the 05/2022 date printed on the controller's label.
In a first step, I wanted to open up the motor and add thermal paste around it, but seem like the motor is just glued now, with what appear to be some soft silicone glue (see the picture).
Any idea why they did that? I don't think that stuff there have anything to do with heat transfer.
Overall, the motor seem more noisy that the old one (I least I think it is).
The older one did not have a throttle, this one does. I did run it from the throttle at "maximum" power (my bluetooth BMS did show around 80W drawn from the battery (48V battery), for a few minutes. It got very warm to the touch at the end (external case - not internal motor), did not expect this as it was without any load.
I will dismantle the entire motor, to change the lubrication with something that I think is better and do other mods too. I have done this for the older motor (just after purchase and before use) and I had no problems for 1500 Km on steep trails.
