neptronix said:
Was wondering if anyone has ever taken an eZip trailz and attatched a brushed DC motor and better batteries.
There are looking cheap to buy with dead batteries. I saw one on CL for $100 the other day and i was thinking.. hm, maybe this could be a cool start project; the motor and battery may suck but it's clean/OEM looking and has the mounting for a chain driven motor from the factory.
Any opinions?
I got an izip for $100 today. So I'm wondering now if you live in Toronto too. It's not in the best shape as some things need to be replaced. Which is alright with me. I'm teaching myself bicycle mechanics. So I thought hey why not refurbish an ebike
. Figured the best way to learn was the same way I learned about computers, buy one, tear it apart and then put it back together,and hope it still works, lol. Figured for $100 even if I do screw it up it's ok. I'll have parts for something else, controller, motor and throttle work great. I got to try it for a bit. Little motor is more preppy than I was expecting. I could only try it in short bursts because the drive chain kept derailing (misaligned chain and improper tension).
Now for what's wrong with it:
1. Rear wheel needs to be completely replaced. The freewheel on the left side is damaged because the bearings wore out (seller was very honest about this). He tried to improvise by use a hub from the front wheel of another bike. However it doesn't line up and the drive chain falls off. The right side freewheel wheel, the gear cluster is worn out. Some of the teeth are bent. I'm planning on calling Currie to get a new rear wheel. But if anyone has suggestions for some other place let me know.
2.) Cantilever brakes need some serious adjusting and new pads. I'm gotten so use to disc brakes that I can't remember how to adjust Cantilever brakes.
3.) Rear derailleur needs to be replaced or adjusted. Need to take a look again to be sure. (EDIT: It's a little rusty, nothing a dremel won't fix. It's bolted on completely wrong too.)
4) Gear shifter needs adjusting but that will have to wait until I get the new wheel/rim
That's about all I can think of right now. The previous owner told me the bike had an completely aluminum frame. But considering the weight (it feels heavy) and the fact that the magnets I have lying around stick to it. I'm going to say it's not 100% aluminum.
I'll try to add pictures tomorrow.
-Vic
