The thing is, I've now done enough days of dyno testing EVs to realize, any/all mass given towards a multi-speed transmission is instead re-applied towards making the motor stator iron and copper and magnets larger, the end result is higher continuous power delivery and efficiency, simplicity, longevity.
Remember, only the iron-copper-magnet mass is performing the transformation from electrical power from the battery into useful shaft work. Everything downstream of that energy transformation device is causing you parasitic losses on the way to turning your wheel, no matter how clever the design.
For the reason, ones focus is best spent finding or making a motor with the desired magnetics to accomplish your desires in the torque required over a given RPM range.
You make good points liveforphysics.
BUT
seeing this guy put teeth that work on what looks like the cone CVTs we know is more about those
rare self enlightening;
"WOW! Holy Da Vinci, Newton and Einstein!"
moments..!
ie: It's not a CVT;
it's a 58 speed (in the prototype. Could be more or less)
toothed cone, with the gear changes of a CVT (kinda)
and the efficiency of a manual gearbox. (no slip)
It's well worth watching simply to expand one's own... 'self'. Do take a look!
(My reply to calab above expounds on things some too)
http://new-cvt.com/
I quite agree that larger hub motors, with field advance etc are the way to go... until you start talking about:
* Potholes: There are millions of pot holes large enough to bath in here (New South Africa) so unsprung weight isn't just a handling/grip disadvantage; destroyed tires and rims is de-rigueur around here.
* Larger, heavier vehicles. Especially rear wheel drive ones. (simple power transmission) and cost/availability.
I'm researching with an eye to an enclosed velomobile type vehicle.
Mostly for personal security. (Higher murder rate than the Vietnam war here atm)
But also for safety, weather proofing and aerodynamics.
So more of a small, aerodynamic, economical tandem 'car' type conveyance, capable of around 120km/h, using off the shelf motors, Fat Tires/rims, etc.
Something Raht Racer-ish, but better looking, sturdier, leaning and tandem.
That would likely be easier and cheaper to accomplish with a 2 or 3 speed gearbox/es , capable of regen and coasting, don't you think?
(I'm also thinking; possibly a parallel ICE as; thx to Load Shedding in the... 'New South Africa', electricity is off as much as it's on and getting worse. So besides an economical conveyance, this half baked vision of mine might provide some power when/for home. Solves the gearbox issue too, for one of the wheels at least)
