LMX P2 : Freeride trials motorcycle frame development
brumbrum   100 kW
Re: LMX P2 : Freeride trials motorcycle frame development
Post by brumbrum » Mar 22 2018 9:30am
maitilupas wrote:
Mar 22 2018 8:11am
than should I try this ? i want fast throttle but also want a smooth ramp
No smooth ramp up on Lyen controller, just one big hit of max amps. Very twitchy and dangerous on powerful bike. I think there is a way to make a throttle tamer but I have never tried. It is well documented on the forum. I think a Cycle analyst v3 can tame throttle. It can be done by using ‘current’ throttle settings in CA v2.3 as well. If you look up the manual for a CA v2.3. It will show you
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
maitilupas   100 W
Post by maitilupas » Mar 22 2018 2:56pm
i red before about that throttle tame, but thining about if using that is realy worth to give up kelly which has very nice features just because of a few ms, i have to investigate about those controllers than .
well i come from the motorcyle backgound and i notice allot the lag even if its close to zero i just notice it.
you dont want that, specially for trials
brumbrum   100 kW
Post by brumbrum » Mar 22 2018 3:26pm
I wonder if these controllers would work with th lmx motor? https://endless-sphere.com/forums/viewt ... 31&t=75888
I suspect not as i did read somewhere that the lmx motor would not work well with sinewave controller. Anyone know any different?
maitilupas   100 W
Post by maitilupas » Mar 23 2018 1:43am
have a look into these, think kelly made a special programming for the motors of these guys , maybe to consider?
http://www.eastgem.net/accsesories.html
skeetab5780   10 MW
Post by skeetab5780 » Mar 23 2018 7:34am
maitilupas wrote:
Mar 23 2018 1:43am
that is where I got my KLS7218SW and it does not work with my LRHDD which is similar to the LMX motors I think
madin88   1 GW
1 GW
Post by madin88 » Mar 23 2018 9:56am
maitilupas wrote:
Mar 23 2018 1:43am
The LMX motor is better because it has a wider stator which means more torque and better efficiency under load :wink:
brumbrum   100 kW
Post by brumbrum » Mar 23 2018 11:24am
madin88 wrote:
Mar 23 2018 9:56am
maitilupas wrote:
Mar 23 2018 1:43am
Yes, lmx is 60mm stator.
I need to purchase a controller and although the kelly kbs18 will do the job nicely the programming software looks really rubbish lol. It seems to have arbitrary units and strange function titles from the screen shots i've seen.
skeetab5780   10 MW
Post by skeetab5780 » Mar 23 2018 6:05pm
brumbrum wrote:
Mar 23 2018 11:24am
madin88 wrote:
Mar 23 2018 9:56am
maitilupas wrote:
Mar 23 2018 1:43am
KBS programming is better than KLS IMO
im ready to buy another KBS
maitilupas   100 W
Post by maitilupas » Mar 24 2018 12:39am
Yeah the kbs interface is nice
By the way they say kbs don’t work with Bluetooth adaptor but they do! Tried myself.
The Bluetooth interface that’s horrible but handy
Check fany from kelly in this video walking trough
https://vimeo.com/205221244
brumbrum   100 kW
Post by brumbrum » Mar 24 2018 2:39am
Thanks guys, thats good to know, and cheers for the video link :D
Yea, it was the KLS interface that i had seen,, very bad.
As you say the KBS is much better. I just looked it up on kelly website. Good :D
brumbrum   100 kW
Post by brumbrum » Mar 24 2018 9:07am
Is anyone running higher than 16s/58v nominal or is this the sweet spot for motor rpm and amps.
maitilupas   100 W
Post by maitilupas » Mar 24 2018 1:36pm
yes myself I use 20s, but im curious to try the 16s, it might be a sweet spot as you said.
found this :
spinningmagnets wrote:
Aug 11 2016 8:20pm
If using the BHT, the single reduction would work best with a higher voltage, but...if using 48V/52V, the higher kV of the Lightning Rods motor + jackshaft would result in a better torque at the rear wheel.
More testing on the KBS72151E today:
Pushed the bike more and had no problems with overheating.. The only noticeable issues were when I kept full throttle for a while like a
min, the continuous amps eventually dropped from 70s/80 to 60s and even 40s but that actually protects the motor and everything aha
Im also curious to try the new motors lmx as i have an old version and new ones tend to drop less or heat less
how do you cool these motors with liquid? hard job?
spinningmagnets   100 GW
Post by spinningmagnets » Mar 24 2018 3:46pm
All it takes is time, tools, and money...
bzhwindtalker   1 MW
Post by bzhwindtalker » Mar 26 2018 8:18am
Mar 24 2018 3:46pm
We did it back in 2016, on the 50mm motors, but we found out the weight and complexity was not worth the improved/constant cooling rate. It sure did a big difference, but was turning our cheap motors into very expensive ones due to manual work and disassembly.
We switched to 60mm and not looked back.
Adam
bzhwindtalker   1 MW
Post by bzhwindtalker » Mar 26 2018 8:21am
skeetab5780 wrote:
Mar 23 2018 6:05pm
Please only use KBS with our engines. it has been tested multiples times with sin wave like KLS or adapto, never with good results due to non ideal hall sensor signal. the Denzel engine is compatible with KLS because it uses external hall, probably with cleaner halls signals, but it adds bulk and weight.
Adam
bionicon   1 kW
Post by bionicon » Mar 26 2018 12:59pm
How does the power of the lmx engine relate to a hub motor like the qs205, to get an idea of ​​the power of the lmx engine?
maitilupas   100 W
Post by maitilupas » Mar 26 2018 1:17pm
bionicon wrote:
Mar 26 2018 12:59pm
I dont know , but I would like to kick ass a stealth bomber with my lmx :)
skeetab5780   10 MW
Post by skeetab5780 » Mar 26 2018 4:23pm
maitilupas wrote:
Mar 26 2018 1:17pm
bionicon wrote:
Mar 26 2018 12:59pm
That will be easy off road, less weight more torque/ hill climb capability, less unpsrung swing weight...easier to change flats
sn0wchyld   1 MW
Post by sn0wchyld » Mar 26 2018 10:58pm
bzhwindtalker wrote:
Mar 26 2018 8:18am
Mar 24 2018 3:46pm
Adam
^^ this
generally, if you want more continuous power, your best ROI will come from putting more weight and volume into copper and iron, rather than water, radiator and pumps. 2kg of the latter buys you a lot of the former, with the added benefit of more peak power, and typically higher efficiency too! The only reason to go to active cooling is if you've filled whatever space you can where your motor resides with copper and iron first. There are some exceptions (such as a hub motor, where the extra weight may be better placed on the frame by way of pumps and radiators than more unsprung weight) but generally, invest in Cu and Fe before H20 and Al.
sn0wchyld   1 MW
Post by sn0wchyld » Mar 26 2018 10:59pm
Mar 26 2018 8:21am
skeetab5780 wrote:
Mar 23 2018 6:05pm
Adam
KBS/KLS - what controllers are these? chs
madin88   1 GW
1 GW
Post by madin88 » Mar 27 2018 2:22am
sn0wchyld wrote:
Mar 26 2018 10:59pm
KBS = trapezoidal controllers
KLS = sinewave controllers (which seems to be way more sensitive in terms of hall signals or probably motor design generally)
The kits from Denzel also have trapezoidal controllers (even the large D7500 one which would have the halls outside and away from the windings).
skeetab5780   10 MW
Post by skeetab5780 » Mar 27 2018 4:49am
sn0wchyld wrote:
Mar 26 2018 10:59pm
Mar 26 2018 8:21am
skeetab5780 wrote:
Mar 23 2018 6:05pm
Adam
The brand is kelly controllers you can just google its a huge company
brumbrum   100 kW
Post by brumbrum » Mar 27 2018 5:17am
What about a matching bms for the lmx motor. I am currently hunting one down. I suppose 50a continuous and 120a peak at a minimum? Or is that conservative?
I am finding it particularly difficult sourcing a bms that will be reliable and has the correct amp rating and has a seperate (C-) port for a charger plug.
If anyone has any ideas please post it up. I have asked Bestech in China if i can purchase this... http://bestechpower.com/592v16spcmbmspc ... 223V1.html
But have heard nothing back yet, and they probably over charge for single item or have minimum order.
I see that on the LMX website there is a 50a bms for sale, but there is no information or images , so i am not sure if it will be compatible with the current lmx motor. Adam? Any details on the bms you sell?
maitilupas   100 W
Post by maitilupas » Mar 27 2018 6:07am
brumbrum wrote:
Mar 27 2018 5:17am
maybe these?
http://www.eastgem.net/bms.html
brumbrum   100 kW
Post by brumbrum » Mar 27 2018 7:41am
maitilupas wrote:
Mar 27 2018 6:07am
brumbrum wrote:
Mar 27 2018 5:17am
maybe these?
Looks really good , though its android only , no IOS Which i would need.
