Hyena
Alrighty, so the flux's bread and butter is going to be hub motors but I'd love to build a sweet mid drive
So, non-hub aficionados, sway me to the dark side
My requirements are:
A: Neat. I want as much of it contained inside the frame if possible. Maybe the motor half or 3/4 hanging out the bottom ? Ideally don't want to see any of the reduction gear externally. This is a steel frame so can easily be cut and welded to. Something like Thud's sweet 2 speed drive could be excellent. Thoughts Thud ?
B: As quiet as possible. You can't argue with the power:weight benefits of RC screamers but I've grown rather attached to the complete silence you get from a hub and sinewave controller. Big block style motor ? Transmag ? Something else ?
C: Equal or better performance to a cro motor or similar running 10kw bursts. Or if the size and weight can be kept to a minimum maybe I'd be happy with around 5kw (I think that would be the minimum). This rules out running through the bikes gears. A bigger/more powerful motor direct driving straight to a large rear sprocket would probably be ideal from a simplicity point of view but I'm open to suggestions on some sort of combo that will yield quiet results (internal chain reduction, external belts, etc)
Here's what we've got to work with:
The frame is 120mm wide at the side covers, other rough dimensions as below. Obviously I'd have to eat into the battery space but that's OK. A larger motor half protruding with no reduction shenanigans inside the frame would be preferable though to maximise battery space.
Maybe something like this as a finished look ?
