windburner   100 mW
Post by windburner » Feb 07 2020 1:26pm
Using the stlink, I updated the data memory, as per the eco-bike article, to get past the 48V full charge voltage issue, but it had no effect on the problem. When I tried the 52V firmware to get past this issue (which did work, but caused the battery status indicator to show low-mid voltage), changing the data memory did work to restore the proper operation of the battery status indicator, however, the 52V firmware introduced another issue that led me to try the OSF so that I could use a fully charged battery.
TerraTrike Rover Tandem - TSDZ2 48V 750W - 13AH Batteries - VLCD6-->SW102/v0.6.8 OSF-->VLCD6
Cristian   10 mW
Post by Cristian » Feb 07 2020 1:27pm
Does anyone know where i can buy a 52v battery in the EU? I have TSDZ2 with OSF running 48v and i want to upgrade to 52V and leave the 48V battery for my wife's bike, which will is also getting a TSDZ2 with OSF.
Should i upgrade to the 850C? Is it worth the cost? I'm on KT-LCD3 for 1 year and 2000km. Running so fine, it's been great, trouble free.
skestans   100 W
Post by skestans » Feb 07 2020 2:56pm
Cristian wrote:
Feb 07 2020 1:27pm
If it ain’t broke...
johnybigh   1 µW
Post by johnybigh » Feb 09 2020 12:34pm
Is any issues to 36V motor powered by 14s battery? Overheating or something?
Cristian   10 mW
Post by Cristian » Feb 09 2020 4:11pm
skestans wrote:
Feb 07 2020 2:56pm
Cristian wrote:
Feb 07 2020 1:27pm
No, it ain't broke. But I still have to get another display for my wife's bike to run OSF. So I was wondering if I should get the 850C or would a KT-LCD3 be enough. But I guess I will be giving the LCD3 to my wife, she will be pretty happy with it and I'll get a 850C.
thineight   100 W
Post by thineight » Feb 10 2020 2:34am
Cristian wrote:
Feb 09 2020 4:11pm
skestans wrote:
Feb 07 2020 2:56pm
Cristian wrote:
Feb 07 2020 1:27pm
In case you may also evaluate to use the open source firmware (v.20 casainho-buba) recently ported for stock displays.
See
viewtopic.php?f=30&t=98281&sid=31349e2f ... 5#p1528052
And previous posts.
MTB KTM Ultra 29" - City bike DAYTONA 28"
Waynemarlow   1 kW
Post by Waynemarlow » Feb 10 2020 8:39am
johnybigh wrote:
Feb 09 2020 12:34pm
No problem, just make sure you limit the battery amps to a level which will keep the motor under 550W - 600W or so, you can pull a lot more, some are mentioning 800W's or so, but the temptation is to use that sort of power on long climbs and as Casainho found, you can damage the magnetism of the motor.
Casainho's & Buba's FW also allows a temp sensor to be fitted which allows short bursts of power in relative safety from damaging a motor.
manoz   10 mW
Post by manoz » Feb 10 2020 11:07am
So I have had yet another motor fail on me, this time I was able to diagnose the problem. It's the controller. I connected the motor unit to another controller and it worked fine. I just need to switch the controllers. I understand you have to remove the cover on the drive side and then 2 screws. Then there's some sort of black silicon for "water proofing". Any tips on removing that? Is that the only things holding the controller in place?
Gyuri89   10 µW
10 µW
Post by Gyuri89 » Feb 10 2020 11:13am
Hi,
Please help me to trouble shoot my problem.
Yesterday storm Ciara hit the UK and my bike too. :(
After a heavy rain I went home and everything was ok with the bike so far. I disconnected the battery and charged it. After having some rest I wanted to go out again and as I switched the power on with the on switch and all the digits came active on the display and it didn't change. Since then nothing is working and switching off is impossible with the KT-LCD3 switch. I can switch it off with the battery switch.
https://drive.google.com/open?id=13BSOS ... uQG8Q8i0kS
I took it apart everywhere where it is possible to get soaked but I didn't see any water. Tried to dry it with hairdryer but nothing changed.
Previously the same happened to it in the summer but that time it got cured on its own after a couple of hours. That time was a bit different as the display was always on automatically when the battery witch was on.
I guess it is the switch of the KT-LCD3 that's got some water and there is a short circuit in it.
How could I test it? Which cables in the display should I test and how to detect a short circuit in the switch?
Thank you guys!!
LJay   1 mW
Post by LJay » Feb 10 2020 11:30am
windburner wrote:
Feb 07 2020 11:12am
Anyway, when I switched from the VLCD6 which does not report a voltage number to the SW102 with OSF which does, the voltage reported is 1.3 volts higher than a direct reading from the battery with a voltmeter, so, my guess is that the component on the controller board responsible for voltage measurement has a very loose quality check.
So the core of the problem most probably lies in high tolerance of resistors used in the voltage divider.
Question is, how the manufacturer repairs this issue, for a warranty claimed units (fw changes or controller replacement).
Waynemarlow wrote:
Feb 07 2020 11:30am
Buy yourself an STLink and reprogram the voltage, its very easy and only costs a few Euros
Follow the link here
https://www.eco-ebike.com/blogs/eco-cyc ... romscratch
ri53hu wrote:
Feb 07 2020 12:18pm
LJay.
Nebo here, the link explains everything. https://www.eco-ebike.com/blogs/eco-cyc ... rogramming :D
I know about this option, but I'm not sure if it is the right solution for the full charge problem. Voltage value modified in this tutorial is most probably some global constant, that changes behavior of whole firmware, not just HVC function.
ri53hu: zdravím dalšího Čecha :)
ri53hu   100 mW
Post by ri53hu » Feb 10 2020 12:20pm
LJay wrote:
Feb 10 2020 11:30am
windburner wrote:
Feb 07 2020 11:12am
Waynemarlow wrote:
Feb 07 2020 11:30am
ri53hu wrote:
Feb 07 2020 12:18pm
LJay.
LJay: taky zdravím.R.
manoz   10 mW
Post by manoz » Feb 10 2020 9:54pm
I've managed to switch the controller in my motor since my other one wasn't working but now the motor feels different. It isn't providing as much acceleration as before. Typically I can get by on assist level 2 but now I find myself putting it in assist 3 or 4 and then turning it down to 2 as I get up to speed. What could have caused this?
James Broadhurst   10 W
Post by James Broadhurst » Feb 11 2020 4:30am
manoz wrote:
Feb 10 2020 11:07am
Once the screws are off (and the 3 motor screws) the controller should be loose but held in place by the black rubbery stuff. For that, go into a coffee place and acquire a good few of their coffee stirrers, and use them to poke the mastic out and then clean it all off.
The only problem I came across was getting the motor cover off. The M4 screws were corroded into the aluminium. In the end I had to take an angle grinder to the heads of the screw and then a set of mole grips to what’s left of the screw. A bit disgusted to admit this as I’ve had years of experience getting these Allen head or cap head screws off and rarely failed.
Edit: I see you’ve managed it! The change in assist level (to achieve similar performance) might be simply different torque calibration.
casainho   10 GW
Post by casainho » Feb 11 2020 6:43am
manoz wrote:
Feb 10 2020 9:54pm
I don´t have a clue, that is strange, I would not expect that to happen.
- TSDZ2 OpenSource firmware
manoz   10 mW
Post by manoz » Feb 11 2020 9:16am
James Broadhurst wrote:
Feb 11 2020 4:30am
manoz wrote:
Feb 10 2020 11:07am
I managed to get hold of some long needle nose pliers and grabbed the stuff and pulled it out. Used some gorilla silicon to fill the void and wrapped the cover in electrical tape to fill the gaps around that part of the casing. When I took that cover off to access the screws that hold the controller it was full of corrosion so maybe that's why the controller failed. The bike is being ridden 50-60 miles a day in British Winter and we are having a very stormy winter.
Yeah I've only got 2 screw on the motor cover. I had to dremel the head off the other 2 since I destroyed the heads trying to get them out. I'll use mole grips to remove them and order some higher quality screws? The strange thing is I had wrapped the seam in electrical tape and when I took that tape off to access the screws the heads of the screws were full of grit.
volcamin   1 µW
Post by volcamin » Feb 11 2020 9:17am
el_proletario wrote:
Mar 11 2019 2:34pm
Is anyone getting some regular creaking noise from the axle while pushing the pedals hard ? Going up hill or just accelerating on flat roads same noise...
I have regreased and tightened all the elements that hold in place the motor on the frame to eliminate this possibility, so it looks like it's coming from the motor itself.
Just wondering if any of you had this issue so far ? (Also, I have a coaster brake version).
I will probably have to send it back to China or Italy for repair (seller pswpower) and that will take some time :( My next motor will be a bafang, hopefully more reliable.
Hello, i recently got this same problem, have you or anyone else figured out what was it? Its sounds pretty serious and i just tightend all bolts and added little bit of rubber between the frame and the motor. I have only 410km done on this motor.
Thank you
manoz   10 mW
Post by manoz » Feb 11 2020 9:18am
casainho wrote:
Feb 11 2020 6:43am
manoz wrote:
Feb 10 2020 9:54pm
It's managed to fix itself somehow, very weird
manoz   10 mW
Post by manoz » Feb 11 2020 9:22am
volcamin wrote:
Feb 11 2020 9:17am
Mar 11 2019 2:34pm
Thank you
Did you put grease between the motor and bottom bracket? Personally I cover the bottom bracket shaft in grease, except the thread which I use thread lock for. Also grease on the part of the motor which butts up against the side of the bottom bracket. Like the other user did, old inner tube wrapped around chainstay for the anchor also helps. Though on the drive side can only put inner tube on top of chain stay otherwise not enough room for motor. I've done nearly 5000km and the bike is nice and silent and I push hard on the pedals since I love to sprint out of the saddle and we have lots of hills too
ezrider1199   10 W
Post by ezrider1199 » Feb 11 2020 9:26am
manoz wrote:
Feb 11 2020 9:22am
volcamin wrote:
Feb 11 2020 9:17am
Mar 11 2019 2:34pm
Thank you
If you have a healthy motor and if you have creaking when pedaling chances are the crank arms arent tight enough. The square spindles are pretty crappy in general and you have to tighten it really hard - that was my experience to get rid of creaking. I also had another issue early on because the motor had significant play in the bottom bracket so i created a shim out of aluminum flashing to fill most of the space (that really helped).
Post by James Broadhurst » Feb 11 2020 10:52am
Mar 11 2019 2:34pm
I’ve had this almost with every motor and it’s always been the pedals. Repeated poking grease into the bearings can sometimes cure it.
Post by James Broadhurst » Feb 11 2020 11:08am
manoz wrote:
Feb 11 2020 9:16am
..... order some higher quality screws?
High tensile black self-colour hexagon socket cap screw. Bike disc callipers are attached with these.
manoz   10 mW
Post by manoz » Feb 11 2020 11:10am
Feb 11 2020 11:08am
manoz wrote:
Feb 11 2020 9:16am
Yes thanks, will look on ebay. What size are the screws for the motor casing? Have tape wrapped around my casing so difficult to get to
beardydave   10 µW
10 µW
Post by beardydave » Feb 11 2020 12:02pm
skestans wrote:
Feb 06 2020 10:54am
beardydave wrote:
Feb 06 2020 8:21am
Can you show on a picture which part you’re upgrading? I have difficulty visualizing it.
This bit, borrowed someone else's image
manoz   10 mW
Post by manoz » Feb 11 2020 12:22pm
beardydave wrote:
Feb 11 2020 12:02pm
skestans wrote:
Feb 06 2020 10:54am
beardydave wrote:
Feb 06 2020 8:21am
This happened to me to, thankfully I had a spare motor and took it from there. I emailed the store on aliexpress and they sent me one for shipping costs.
skestans   100 W
Post by skestans » Feb 11 2020 3:45pm
beardydave wrote:
Feb 11 2020 12:02pm
skestans wrote:
Feb 06 2020 10:54am
beardydave wrote:
Feb 06 2020 8:21am
I'm probably being really thick at this point, but... That's the shaft the cranks are attached to?
