Hi All,
I need some advice for a robust rear drop out for 12mm through axle. WIll be without a derailleur and fixed gear. Disc brake. Mechanism for chain tension adjustment would be needed.
My thoughts were to mimic what motocross have for rear wheel mounting, which also includes the rear caliper mount any thoughts?
I'm new to mountain biking (have a motorcycle background) but I'm planning a build using the tangent-Dave system for the build.
The plan will be to have a thick section carbon fiber rear swing arm similar to what sportbikes have. If there are no suitable off the shelf parts from frame builder suppliers then the drop outs will be milled out of Al and bonded into the carbon.
Any links for existing dropouts or suggestions would be great!
Thanks.
Thanks.
