BBSHD - Creaking Sound
Fastest1   10 W
Re: BBSHD - Creaking Sound
Post by Fastest1 » Jun 03 2017 1:18pm
you could always print a sleeve. Well if you know anyone with a printer.
AntonyFree   1 µW
Post by AntonyFree » Feb 08 2020 12:59am
Thanks for contributions - I tried the crank tightening suggestions and that seems to have worked. Mine was a definite creaking sound, not squeaking. I've just tightened up the cranks and went for a short ride - the creaking seems to have gone. I'll update if it comes back. So, re tightening the cranks, I used a large Allen key (hex key, Allen wrench), and with the bike upside down, key and crank arm at about 180 degrees, pushed (with large folded rag for cushioning) with all my strength. I had to do that a few times each side. You push hard and it tightens, but then you find you can push hard some more and it still tightens more etc.
P.S/ I just went for a slightly longer ride. Starting off without e-assist there was some creaking again. I'll just live with it for a few days probably, and see if it goes away. Otherwise I'll take the crank arms off and have a good look at them. Perhaps some water got in when I washed the bike last weekend. Would water in the crank arm connection cause creaking?
Wolfeman   100 W
Post by Wolfeman » Feb 09 2020 12:17pm
I own and maintain 2 BBS02 bikes. Any time I start hearing creaking I snug the crank bolts and tighten the locking ring on the bottom bracket shell. Prodigious amounts of red Loctite make these tightening intervals much longer.
Trek 4300 w/ H3580 Crystalyte at 3600W
viewtopic.php?f=3&t=82738
Worksman Mover M2020-3CB w/DD 750W front hub
viewtopic.php?f=3&t=96873
Dyno Moto 7 BMX Cruiser w/BBS02
viewtopic.php?f=6&p=1467001#p1467001
GT Palomar Vintage hardtail w/BBS02
viewtopic.php?f=6&t=104255
