OpenEMoto
trazor
I want to show my latest creation:
10-jpg.227704
11-jpg.227705
15-jpg.227706
20-jpg.227707
25-jpg.227708
26-jpg.227709
30-jpg.227710
40-jpg.227711
50-jpg.227712
60-jpg.227713
65-jpg.227714
66-jpg.227715
67-jpg.227716
70-jpg.227717
80-jpg.227718
An important highlight is that i'm releasing all source files for the build: GitHub - eroldan/OpenEMoto: Open source electric motorcycle
The project is made on Autodesk Inventor.
What is missing now is a guide of the build process. Writing one is a big task. Let's see if people is interested. I can answer here for now. About the build process I can say that I've built this bike with:
  • TIG welder
  • Angle grinder
  • Press drill
  • Car type hidraulic bottle jack (2 ton)
  • Lot of mild steel
  • Drill bits and cup saws
  • Printer+sticker sheets
  • Small hand tools
  • Few dollars for a lathe operator
  • 3d printer (to build the welding jig)
A waterjet or CNC plasma cutter probably can accelerate the build by a big factor. I've cut the plates by angle grinder, and some are tricky.
As you can see, i've tried to design in a minimalist way to easy build and reduce weight. I think it is impossible to get rid of any part without taking some function. With my 720Wh battery, the bike is weighting 40Kg.
The design goes toward a trials bike (style that I enjoy). The seat is low, and that makes dismounting very easy. Probably a new seat mount can be done to make it more "enduro".
Does anyone want to build it?
I will post videos soon. My riding mate & camera man is on vacation.
I love it!!!! I think the swing arm mounted motor makes a lot of sense. Of course a small increase in unsprung weight but you can't beat the simplicity. The use of all straight tubing is fantastic and the use of 3D printed parts to jig it up is genius. Also, in the picture, where the frame is jigged up, it looks like there are some white pieces that marked how cope the ends of the tubes. Are these 3D printed or flattened in CAD then printed on paper and then wrapped around the tube? The design and execution in my opinion are top notch and the finished product is a great looking bike! Well done!
What rear hub is that? OSET? LMX?
Thanks! I really appreciate your kind words. I've put a lot of nights (and days) on this project and sometimes I felt a bit alone :)
You are right, the "white pieces" are prints made with my inkjet printer on sticker paper. For example https://github.com/eroldan/OpenEMoto/blob/master/MainFrame/Cuts/B1.pdf
Here is the drawing that names tubes: https://github.com/eroldan/OpenEMoto/blob/master/MainFrame/TubeNamesAndDimensions.dwg
and here is the exact placement distances (you need to "index" the tube with a straight line and use that reference to apply the sticker) https://github.com/eroldan/OpenEMoto/blob/master/MainFrame/Cuts/CutsPositioning.pdf
For the tube notch shapes, I exported surfaces and flattened using this "Papercraft" software http://www.tamasoft.co.jp/pepakura-en/
Ecellent question! The rear hub has taken a lot of thinking time because I can't afford to machine a hub or buy the expensive ones (and make my design around them, not the other way).
The hubs are tweaked aluminum old school threaded hubs: https://www.ebay.com/itm/2x-Bike-Bicycle-Cycling-Mountain-MTB-Disc-Brake-Hub-SET-Rotating-36-Hole-TOMOUNT-/273017606162?hash=item3f911e1012
An adapter from threaded to 6 holes is needed, and I've made one using a 12T sprocket (only the threaded piece) and welding a 6 hole plate ( https://github.com/eroldan/OpenEMoto/blob/master/Hub/ScrewAdapterPlate.dwg )
file.php
The hub ball bearing is replaced with sealed bearings, and a spacer is placed between. Then, this part is used as a spacer to bring the disc near the caliper: https://www.amazon.com/ADEDS-Bicycle-Freewheel-Threaded-Adapter/dp/B01JREIQYG/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1516556568&sr=1-2-catcorr&keywords=brake+disk+adapter+hub
file.php
Here is another option using front hub, with excellent results too:
file.php
There is a 90% complete "Bill of Materials" here (open with Open or Libreoffice): https://github.com/eroldan/OpenEMoto/blob/master/BOM.ods
Excellent job and execution! Looking forward to your videos.
Thanks for building and sharing your ideas.
Tom
really nice design and craftsmanship..
but I don't think a thread on motor sprocket will last very long under high motor power.. the rear sprocket needs to be bolted to the rear hub not threaded on with bicycle parts not designed for motor power.. the cost of a quality rear hub is not that much compared to the cost of a rear wheel rebuild/ redesign.. what is the cost of the battery, motor and controller; these are likely the higher cost components of an electric bike build..
Anyways, can't wait to see it completed and video in action.. best luck:)
efMX
efMX
I agree with you that the threaded connection seems weak. But i've some data, for now, that looks promising:
I've used a steel hub thread for two months, without breaks. (https://endless-sphere.com/forums/download/file.php?id=224977)
Then, i've tried to unscrew the adapter from the steel hub and required enormous amount of leverage to do it. Suceeded and then screwed the adapter again and had a failure in 2 hours. Seems that the threads are deformed after the high torque and don't hold if deformed in the opposite way. So I learnt the lesson: never unscrew these parts.
Then, replaced the broken threaded hub and re-assembled and rode for three months without breaks. Shot this video: https://endless-sphere.com/forums/viewtopic.php?f=28&t=91653
Now i'm riding the aluminum hub used in OpenEMoto and is holding up. Time will tell.
What are the options? Oset sells hubs for 69 dollars, but the measures are not published. They don't seem to be thru axle type, and no information if they have sealed bearings or not (if they use sealed bearings it is trivial to convert to thru axle moto style)
The LMX hub looks good, but at 140 euro + shipping to Uruguay, it is a bit expensive for my budget.
Any other option?
for mid drive rear hub options look for similar mid drive bike manufacturers then contact them for spare parts availability, specs and pricing..
examples would be : LMX, Sur ron, oset, kuberg, Mammoth, Mrazek, SEV, lightning rods, motoped, etc.. or maybe a dual disc hub.. :idea:
efMX
Any other option?
since you are in south america maybe try contacting ecocycle.moto for a rear hub option?
[youtube]oARvmn3Cnz8[/youtube]
facebook.com/Moto10.Colombia/
fechter said:
Nice.
What motor are you using?
Thanks.
Motor is the "big block" that sells lightningrod user. It used to be listed here http://lightning-rods10.mybigcommerce.com/accessories/electrical/motors/ , but you can contact user directly.
If you are curious of the source of other parts, check the BOM: https://github.com/eroldan/OpenEMoto/blob/master/BOM.ods
I've a new video but isn't something cool. I had a crash and broke my Marzocchi 380.
Check this topic https://endless-sphere.com/forums/viewtopic.php?f=2&t=92618
The crash was big, but only impacts with the floor. Still my fork left bottle is bent in some way, and the stanchion can't slide. I feel that DH stuff is very expensive and not so strong. Should I go to pit bike forks? They are 1 1/8 compatible? recommended brands? Other ideas are welcome.
trazor said:
I've a new video but isn't something cool. I had a crash and broke my Marzocchi 380.l.p.
sorry to hear about your crash and bike damage..
you may want to look into a DNM front suspension fork, more reasonable price and pretty beefy.. many people on here are using them for feedback from other riders.. another fork to consider would be the new RST, used on LMX and Sur ron.. most pitbike forks will not be compatible because they are shorter length designed for small diameter pibike wheels and would require modification to the bike head tube diameter or custom made headset steering bearing set.. also check into fast ace forks used on the Sur ron and early model zero electric motorcycles.. best luck, let us know how it turns out..
There is pit bike forks the same length as bicycle double crown forks.
They are not too heavy.
Double crown bicycle fork 3,2kg - 4,5kg, length ~740mm.
DNM pit bike fork is 6,2kg; you can straight put 17'' pit bike wheel and pit bike brakes. Length - 735mm (some sources say 750mm)
in EU they ask 70 pounds. Which is even worse.
Finding rear hub is a problem. Adapting bicycle is flimsy and not sufficient for the application.
You put music over you clip. How is noise?
Are Both rims front pit bike rims?
I will build similarly. Can't decide about the motor.
Don't like chain noise.
Have the option to use 9kg, 21cm length, 120A battery /400A phase motor but I think it's too big for similar bike.
If rear hub fails why don't you get alum pit bike hub.
would you write your front and rear sprocket tooth number and speed you reach with your ebike. Also controller settings, batt and phase amps.
Did you ride hub before?
I'm open to try those pit bike forks. Do you have links?
http://www.ebay.co.uk/itm/BRAND-NEW-GENUINE-DNM-M-200S-FORKS-735MM-FOR-UPGRADE-PIT-DIRT-BIKE-I-FK07/330856972899?epid=1491676839&hash=item4d089cc263:g:jXgAAOSwPCVX9qFx
Aliexpress few sellers sells them, but try your local shops also as it might be cheaper to buy locally than to get it from CN.
With the "big block" motor at 72v, with 12t sprocket and 92t drive, I get 55Km/h. The torque is "a lot".
I use a Kelly KBS 80AMP with all settings at "maximum" :)
Altough not the same frame, the transmission is the same and sounds like this https://www.youtube.com/watch?v=7YO6QAL7AyU&t=112s
I ride a MXU3k hubbie too. If a hub sounds 1 and an MX dirtbike sounds 100, I would say that my bike sounds 10. My chain bike does not bother anybody, even if I pass at 1 meter.
If you want cheaper than DNM pit bike fork but without air check out ''Volt'' (only metal springs in both legs), there are V1 and V2; v2 superior. There are even 770mm version which is even longer by few cm than most bicycle two crown forks. It does not have longer travel, only tubes are little bit longer. There are similarly good other pit bike forks for similar price range but I'm familiar with my mentioned ones specifically; check weight before buying as not all sellers specify as it does not matter so much for gas machines; I would say it's not worth if its heavier than 7kg for ebike;
But there is the reason why DNM pit bike fork costs three to four times than Volt pit bike fork. It is good fork.
The same good is FastAce pit bike fork; get whichever; both DNM and FastAce are very good.
Regarding bicycle DNM fork be aware that it is good fork but it lets inside dust and if you ride in dusty environment it will be affected sooner (needs service) than other some high end forks (which are more expensive). I don't know how it is actually relevant in real life... but experienced people are mentioning it.
I got DNM bicycle fork for 325eu shipped from CN.
You can get pit bike DNM for the same price if you really need that strength.
Be aware. Newest DNM bicycle fork has air in both legs, older version one leg has air only in one leg, other leg has metal spring; few hundred grams weight penalty; I prefer the older version.
I don't worry that bicycle fork will break with my style of riding. What I worry is bicycle brakes; rotors are too thin and overall bicycle brakes are flimsy unless it is very high end brakes and still they are not enough at speeds over 70km/h.
Going with pit bike light quality pit bike front (rim tyre caliper rotor house fork) you are looking at additional maybe ~5kg penalty.
Off topic.
I heard one person made HTD M8 rear pulley out of composite material, 125 teeth. Can't ask him as he is Ukranian. If some who reads this are aware how it is done or have examples of those who have done it share it here plz or point where it is discussed.
