Albatros enduro bike.
ferum   100 mW
Re: Albatros enduro bike.
Post by ferum » May 31 2019 2:42pm
Yes, pedals without a motor spin easily. Well, given the total weight of the bike and the suspension travel 200mm. To go fast and long without a motor, a large load. I will make a video, I will pass the segment without the help of a motor. It is difficult to accelerate and go up, maintain the speed easily. This is if you have training. I travel a lot on non-motorized bicycles. On this bike, normal ergonomics.
Grantmac   10 kW
Post by Grantmac » May 31 2019 7:04pm
Having both a useful cadence and being able to pedal unpowered is VERY impressive. I look forward to seeing how the Alfine lasts over time.
damirsky   1 W
1 W
Post by damirsky » Jun 03 2019 1:10pm
ferum wrote:
May 30 2019 3:28pm
Please teach how to insert a video, not a link?
put not the full link like this:
https://youtu.be/fQL7zYq9qv0
but just the last part after the slash:
fQL7zYq9qv0 (this only)
ferum   100 mW
Post by ferum » Jun 04 2019 10:30am
Promised photos for the latest upgrade.
  Goals:
1. lift the bottom bracket (I got upset, dropping the BB in -20mm, this is the height relative to the axles of the wheels, eventually on 26x wheels and two hundred millimeters of suspension travel, in corners and in the forest I bumped the hummocks with pedals, brought it to 0mm)
2. Increase Rich frames. In the rack was cramped to me. Increased by 30mm.
3. Finally, I normally assembled the pipes in the front. Now I like it!
Feist92   10 mW
Post by Feist92 » Jun 09 2019 2:35pm
You do very nice work, this goes well beyond everything else I've seen here. Definitely going to have to use this for inspiration for my next build.
I thought the surron had a nice frame but I much prefer this
ferum   100 mW
Post by ferum » Jun 24 2019 2:58pm
Hi everybody! Made a video with telemetry. I ride in this mode, until nothing is broken. If I raise the saddle and twist the pedals, then my back is very tired to go standing. The run on the battery in this mode is 50km, or 3 hours, but the forces end earlier. Always 30 percent of the charge remains. For economical driving plan for the movement torque sensor on the pedals.
ltu   100 mW
Post by ltu » Jun 25 2019 11:25am
beautifull bike
final weight?
how do you feel the bike?usualy in dh bike the top rider have around 450-460 mm reach seme wheelbase beacuse prefer more weight in back wheel.
wich is the weight distribution in both wheel?
however amazing job!!!
fechter   100 GW
Post by fechter » Jun 25 2019 2:43pm
Nice video. Great to have the data overlay.
ferum   100 mW
Post by ferum » Jun 26 2019 5:37am
Thanks for the words of support!
Bike weight 39 kg. Geometry issues are very complex. It is necessary to go fast as a DH, but on a horizontal surface, and sometimes up, in contrast to DH. Current trends are 29 "wheels and a long bike.
My height is 186cm, and now I am comfortable. The bike is very stable at speed, and helps out when tired and make mistakes. Perhaps plays the role of a low center of gravity and low unsprung weight rear wheel. Turning is also not bad. Low top tube does not interfere in turns. On braking is not blocked. The rear suspension works well. Distresses the fork. Need something better. Perhaps 27.5 ".
Chainstay frame 440 mm, can be increased to 470. To pull out the front wheel, you need a smaller one, but if you go up, you want more. While experimenting.
An important point, it is convenient for me to pedal when I lift the saddle up. Of course there is a buildup suspension, and the total weight of the bike. To go without a motor, it's like working on a stationary bike. But I can keep the speed of 15-20 km / h for a long time. Now I am working on a torque sensor. If you help with the trigger gas, you always want to add more, and there are no right emotions from riding on the pedals.
In general, I like everything, the prototype does not break from the loads, the transmission and suspension work. I have enough power and battery capacity. But there are many minor amendments, as well as the resource and reliability of lightweight bicycle components should be considered. Maybe soon I will make a new frame, try to reduce weight.
devo1223   100 W
Post by devo1223 » Jun 26 2019 11:24pm
ferum wrote:
Jun 26 2019 5:37am
I love this bike. Let me know if you decide to sell this one
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
E-HP   100 kW
Post by E-HP » Jun 27 2019 1:03am
That pass on the right, at 3:38 into the video, reminds me of those situations where the only thing that will keep you alive is power. My wife would never ride on the back of any of my bikes except the ones over a liter, because it was "safer". I'm going to watch it again cast on my big screen. Fantastic stuff.
namahs   10 mW
Post by namahs » Jun 27 2019 1:33pm
This is a sick build! It looks great!
ferum   100 mW
Post by ferum » Jul 03 2019 5:24am
Hi everybody. There was such a question, maybe someone will help. There is e-MTB, Rocky Mountain Altitude Powerplay, it is not an ordinary transmission system. I assume that the highlighted element is a torque sensor.
Rocky-Mountain_Altitude-Powerplay_eMTB_e-bike-trail-full-suspension-carbon-all-mountain-bike_Powerplay-motor-detail.jpg
Do you have any suggestions?
I will explain my interest. I came up with this design.
Will it work? The controller with the support of the torque sensor.
A carriage with a built-in torque sensor does not suit me. I need an ISIS standard.
DanGT86   10 kW
Post by DanGT86 » Jul 03 2019 9:12am
Might be a little challenging to tune the output of the torque sensor to match the non-linear tension on the chain. As long as you can map the signal coming from the sensor it should work. I would think you could use a strain gauge in an aluminum bracket holding the chain idler to minimize moving parts.
Cool idea.
ferum   100 mW
Post by ferum » Jul 20 2019 2:28pm
Some new photos. We have rain every day.
It was important, protection from dirt and the ability to wash. In past projects, I have not provided for it.
My PAS sensor is almost ready.
racingame   100 W
Post by racingame » Jul 21 2019 2:16pm
Very nice update, I like what I see here. 8)
ferum   100 mW
Post by ferum » Jul 23 2019 10:45am
gidooo   1 mW
Post by gidooo » Sep 06 2019 6:48am
https://electrek.co/2019/09/06/ubco-frx ... ke-50-mph/
This looks vary similar to your design :?: :shock:
bogus105   100 µW
100 µW
Post by bogus105 » Dec 24 2019 9:53pm
WHAT A DESIGN!
congratulation. Tell us please how your bike is now? How many km you made? Any problems?
Could you explain me how have you modified bafang hub motor so now its enclosure is not revolving? And the Alfine IGH - it is modified? Is the hub revolving or what?
When you pedaling - do you drive the bafang rotor? I understand that you have used one way clutch on the small sprocket on the motors shaft so when bafang is driving the bike and you are not pedaling the pedals are still, right?
Could you tell us more about the drive train? It is very interesting!
What is the real life range of you bike? What battery configuration and what cells you have?
I'm really impressed by the mechanical skills and patience you have mate!:)
ferum   100 mW
Post by ferum » Feb 01 2020 7:06am
SlowCo   100 kW
Post by SlowCo » Feb 01 2020 7:23am
:shock:
:bigthumb:
8)
Damn, that is a great build!
fechter   100 GW
Post by fechter » Feb 01 2020 3:09pm
Yes, that really looks great. How do those tires work in the snow?
I never see snow here, just mud, but it looks like it would be fun.
Chambers   10 W
Post by Chambers » Feb 05 2020 9:05pm
Awesome build :bigthumb:
ferum   100 mW
Post by ferum » Feb 10 2020 5:12pm
