etard
Has anybody seen this controller? It seems way sicker than the HV110 for all the dual motor setups, current limited and everything.
Is there any Robot guys here?
Features
* Size: 108mm x 82mm x 28mm (4.25" x 3.23" x 1.1") without optional mounting brackets
* Weight: 365 grams (13 oz.) as shown
* Voltage: 14V to 48V Supply voltage (50V absolute max, down to 6V with external 12V supply)
* Current: 80A continuous each channel (150A peak 5 seconds)
* Current Limiting: Adjustable from 10A to 130A (sets the limit for both channels)
* Over Temp Limiting: fixed at 200F or 93C each channel independently sensed
* Four quadrant operation with regenerative braking
* Thermal Control: MOSFETs mounted to 0.5" Aluminum bars bolted to case (see below). No fans required.
* Indicator LEDs: Speed and direction of each motor channel and general signal status
* Receiver battery eliminator circuit (BEC) standard – may be disabled. Provides up to 100 mA of current at 5V to the RC receiver and other attached electronic circuits
* Command Format: R/C pulse standard, TTL serial optional
* Calibrate button to match Sidewinder to radio or other R/C signal source
* R/C Inputs: Left/Steer, Right/Throttle, Flip (inverts steering response when activated)
* Drive Modes selected via jumpers:
o Left/Right Mix (default - right input acts as steering and left as throttle)
o Mixed Mirror Left (left mixed output command sent to both output channels)
o Mixed Mirror Right
o Left/Right independent (Tank)
o Mirror (both outputs mirror a single input)
* Failsafe shuts off motor if R/C signal is lost
* Six high-current wires (2 battery, 2 each motor) may be soldered or attached via #8 bolt and ring terminals
* Expansion header for planned on-board radio tranceiver and single axis gyro (future). May be used for other special add-ons
* FLASH-based microcontroller with upgradeable software via in-circuit programming header. Software may be customized for unique applications. Contact us if you have special needs for your application.
http://robotpower.com/products/sidewinder_info.html
Features
