Hi, I'm building an electric go-kart using the MY 1020 motor or maybe a clone of it. But unfortunately, I can't seem to get the motor to run at all. Not even powering up. After looking through these forums I found out that I need to connect some sort of e lock cable and power cable. the controller is a chinese make and came with little to no instructions. Could anyone give me some sort of information on what wires to connect to disable the e-lock or motor lock?
This is the wiring information provided in the description.
Installation:
These controllers have 4 groups neccessary cables(power cables, E-lock cables, Throttle-cables & Motor-phase cables), when hook up these 4 groups cables, the E-bike can run normally.
Besides, these controllers have other optional functions, users can hook them up according to your applications.
Connection Table:
1.)Power Cables: big red + big black
2.)Phase Cables: big yellow + big green + big blue
3.)Electric Door Lock Cable: middle red
4.)Hall Cables: small red, small black, small yellow, small green, small blue
5.)Throttle Cables: small red + small blue + small black
6.)Speed Cables: blue(high speed)+ black + +yellow(low speed)
7.)Brake-Hi Cable: yellow
8.)Brake-Low Cable: Brown
9.)Anti-theft Cablesï¼Red(Positive) + Black(power) Red(E-Start) + Blue(Motor Lock Signal) + Green(Motor Lock)
10.)Astern cable: small black + small white
11.)Self-Study cable: two white cables with black plugs
12.)E-ABS(Optical): two blue cables matched
I would really appreciate any amount of help.
Thank you.
Installation:
Connection Table:
Thank you.
