DasDouble
Hi, I have developed a sensor which is able to send multiple informations. It has a
-Temperature module
-Wifi Module (Send, Recive, Scan)
-Sicfox Module (30-40 Meter accuracy)
-Accelleration Sensor (3D)
Im searching for a field of use I could use it for.
Do you maybe have an everyday problem where you want to know a specific information which you could use it for with the these sensors?
It can run with a small battery which lasts up to 3 years if you send the Sicfox Signal for example from time to time but also can be pluged into a power wallet.
I want to bring it on the marked soon but Im still searching for a field of use right now.
-Temperature module
