John Hutton
100 µW
- Joined
- Nov 27, 2019
- Messages
- 9
Right, so I'm looking at upgrading my old touring bike with an ebike kit.
Here is the donor bike: https://i.ibb.co/DQXZGz6/IMG-20190428-131806.jpg I know cantilever brakes are not ideal, but I have Kool stop pads and they are set up very well and stop me easily even with a load on a downhill.
I have decided on a BBS02 750 from the following seller: http://www.pswpower.com/ven.php?cargo.2017-61-s29r 370 dollars.
I'm looking at this battery from the same seller; http://www.pswpower.com/ven.php?cargo.2019-7y-bu86 335 dollars.
I'm in the EU so the exchange rate to euro is good and this works out at a very good price compared to elsewhere, particularly given that this seller says they send it from Germany so there will be no taxes on import to my country.
Has anyone here used PSWPOWER?
I also need a gear sensor. Amy idea where I should get that? I see you can get brake sensors with magnets etc, is it possible to get one similar to the gear sensor and just have the cable from the brakes o have feed through it?
Because I have downtube shifters I don't think the battery will fit there. I'd also like to keep the bottle holder as I can only attach one to the frame. So, I was thinking of just having the battery in a pannier and running the cable from there. It would also ensure the battery stays dry.
I have some queries about the battery set up, do I have to buy connectors and solder stuff? No idea how to do this, so any tips would be appreciated.
Will I need extra wire to stretch it to the pannier?
Any hints tips or feedback is appreciated
