Returnformer
- Joined
- Apr 11, 2019
- Messages
- 90
Ok, so I've got the bike:
now ive gotta figure out the build. im leaning towards getting the 1500w waterproof kit from ebikeling. ive currently got the 1200, and wish it was a bit faster, especially in wind etc, but according to the website the 1200 provides 30 nm torque, whereas the 1500 provides 40 nm torque. so i would think it would fare a bit better. im not looking to double my speed or anything, just need it a bit better. i did have some issues with spokes breaking on the 1200w kit, but once i replaced a few spokes with thicker ones from my old kit, that stopped happening, so i should be able to do that again if needed.
unless someone knows a better similar option?
im also debating a bit where on the bike to mount the battery (shark type or similar). if you look close, theres the brackets that the brake and other cables fit into that stick out slightly past the underside on the downtube. which prevents the battery from being mounted flush with the underside of the downtube except in between them, where it does fit. i tested the suspension with an empty case velcroed there, and theres probably about 1/2 to 1 cm clearance when fully compressed, but i dont think it would bottom out with normal riding, im not doing 20 foot jumps or anything. i found a bracket on grin's site, https://www.ebikes.ca/shop/electric-bicycle-parts/battery-accessories/double-bob.html, which should give it clearance over those brackets to mount it lower down on the downtube, but im waiting on an answer from them on whether it can be screwed into cage mounts or not. i live in brooklyn, ny, and leave my bike unattended while shopping etc, so i dont want it to be attached only by hose clamps, thats too easy to undo. (i know, the battery could be kicked off if someone really wanted it, but thats more obvious and less likely imo.)
another thought was to attach to the underside of the top tube. would that work? or is it not sloped enough?
as far as the battery itself, i was thinking to upgrade to a 52v battery. this should also give me a bit more speed and range, and still be compatible without any special controller, correct? i was initially thinking to get the 52v 13.5 ah shark from luna, but the controller on the 1500w kit is rated for 35 amps and that battery is rated for only 30 amps. this would be a problem, correct? i found a similar 52v 14.5 ah from grin in canada which is rated for 40 amps. this would be good, right? of course, once i was looking around there, i saw the 52v 20 ah battery with similar shape, but taller. (i was also looking at the dire wolf on luna, but it doesnt look like it locks and i dont think the shape would work as well on that frame.) one thought, though, was that if im mounting it on the underside of one of the tubes, will the plastic tabs that hold the battery in place be strong enough for such a large battery? or should i stick to the smaller hailong 1 type if mounting on the underside? if i got the bracket and mounted it lower down on the downtube (or under the top tube) then i think clearance wouldnt be an issue. im just worried about the larger battery falling off since its not as well suppoorted upside down.
thanks.
thanks.
