greenspark
- Joined
- Oct 23, 2011
- Messages
- 176
Back in January 2013, I was visiting the Bafang factory when Yonree showed me a new prototype - the BBS01. Riding it in suit and tie in freezing weather, I asked him to sell me the first production model when it came out. Three months later, they sent me serial number 17, which I wrote up in this forum. After 6 months testing, we did a group buy of 27 motors with EM3EV batteries. I had to convince Paul to give Bafang a second try (helped by introducing him to Yonree - in China it's all about who you know), and had the motors sent to him for shipping along with the batteries. All were 36V except for one 52V that I wanted to try.
Fast forward to 2020, and the 36V batteries are all giving up the ghost, but the 52V had a different problem; the charger quit. Paul sent me a new charger and better connectors than the six-year-old versions, and yesterday I finally got around to putting it all together on a 1999 Mercedes belt drive bike I picked up online.
All was going well until the final link, connecting the positive battery wire to the positive motor controller wire. Using gold bullet connectors, it did not just spark, it gave me a welding-level blue flash that turned my hand black and raised a nasty burn on my thumb. First took some aloe vera growing by the garage to deal with the burn, and then tried to work out what was going on.
I took very heavy battery switch from a jumper pack and wired it in line. Replaced the burned bullet connectors. Battery tested 57V. I tested the positive battery switch feed by grounding the voltage tester to the negative battery bullet connector: 57V as expected. Wearing welding gloves, glasses and welder's jacket, outside in case something blew up or caught fire, I turned the switch on. It made a slight sound but nothing happened. No fire, no heat, very anticlimactic. Pressing the display power-on button, the display did not come on. Turned it off, using the voltage tester, turned the heavy power switch on: zero voltage. At that point, I quit, removed the battery and motor, and cannibalized one of the guest bikes 36V motor and battery which works fine except the power stops if I draw full power (old battery problem).
Does anyone know what would cause such a flash? The flash was like what happens when accidentally touching positive to negative on a car battery, except that should have overheated or melted down something when the heavy on-off switch was switched on.
I am mechanical, but not electrical-oriented. I know the basics of using electrical testing equipment, but not confident to take apart a battery or do more than simple soldering. It may be that at 6 years, I've got my money's worth out of the group buy (I did buy a new 52V battery/BBS-HD kit from Paul when the charger problem cropped up, so my main commuter bike is running fine), but I would like to keep these guest bikes going if I can.
