Heavy fat ebike with hub motor, safe to do jumps?
So I converted a conventional fat bike to a ebike. I used a run of the mill somewhat cheap ebay conversion kit.
http://www.bikesdirect.com/products/mot ... sprung.htm
This is the bike I used, and I believe after the conversion it weighs roughly 70lb.
https://ibb.co/SKPfzky
So, based on personal experience, how hard can I push this bike? Would it probably be able to handle small to medium jumps, or would it be a good idea to just avoid them in general?
Re: Heavy fat ebike with hub motor, safe to do jumps?
Jumping a bike is foolishness, but with that out of the way, if you can jump a pedal bike without wrecking it, this one should be about the same.
___________
Finish Reconstruction.
- dogman dan 100 GW
Well, the wheel build on a typical cheap DD motor is not that great, and no suspension to help soak up the jumps. You can damage the shit out of a cheap built wheel just by letting spokes get loose.
But at least its not a geared motor. With geared motors there is some risk to the gears, or at least the shear pin inside, when you jump with the motor on. Geared motors need to be jumped with the throttle turned off.
But all that said, can you build a nice ramp, fly 4 feet in the air, and land on the flat when you personally weigh 280 pounds? Likely not without risking some bike damage, particularly broken spokes on the rear wheel.
Jumps just vary man. When I was young, I'd huck 100 foot jumps on skis. Maybe 50 foot vertically. But sure as hell not onto a flat hard landing. Landing on a very very steep slope makes a huge difference when you fall 5 stories. Makes a difference when you fall four feet too. But I see no reason little pops, or shorter drops to steep landings could not be done on that bike.
Frankenbike longtail
http://endless-sphere.com/forums/viewto ... cing+betty.
bolt on longtail https://endless-sphere.com/forums/viewt ... =6&t=74584
The mixte long tail. https://endless-sphere.com/forums/viewt ... =6&t=74384
Beach cruiser converted to long tail. https://endless-sphere.com/forums/viewt ... r#p1045572
A 4 ft flat landing drop on hard pack can damage the best hub Motor bicycle wheel build, and most cheap frames at first try.
Jumping is a world of expansive frames and experienced riders. The learning curve is very steep, expansive, and painful. With ebikes, best is to build a robust mid drive on one of the best slopestyle or DH frames. With fat tires, it is custom domain.
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
Current bikes
Street:
Dirt:
I have one of the Gravity Bullseye e-bikes from Bikes Direct. I use it for commuting, but take it out on some local trails occasionally if I'm doing some work and need to lug tools around. I've done some small jumps, but it's sooo heavy, like mentioned, I'd be very worried about the wheels. I knocked a wheel out of round going up a curb fast.
Also, the battery and controller aren't exactly mounted for taking jumps. I could see the battery ripping free of the downtube rivet mounts.
Jumping a bike is the greatest fun and skill that a rider can achieve, but it is not for everyone, nor every bike. I am getting old for that kind of fun now, but I still enjoy it when the conditions are ideal. With a hub motor, big jumps are a thing of the past, but my bikes can jump 3ft safely on the flat or DH, 5 ft uphill maybe more. Uphill jumps are much lighter on wheels, but require considerable power, or speed.
Current bikes
Street:
Dirt:
Current bikes
Street:
Dirt:
I think that fork will bottom out, even riding off a curb, with all the extra weight. 120mm isn't a lot, and you'll have to pump up the pressure to compensate.
my econo-e-bike https://endless-sphere.com/forums/viewt ... =6&t=97945
Hardtail with hub. Depends on what you land on. If soft, you're fine. Root or rocks you will bust a spoke/rim. Same with potholes.
- dogman dan 100 GW
You can go ahead and ride off curbs all you want, for sure, unless you have 6 loose spokes.
The consensus seems to be in, don't do what you'd call a huck unless ready for some damage. Little pops should be fine provided you have no obvious weaknesses in the bike, loose spokes, poor torque arms, etc.
Only if you have a second backup bike.
Just playing the devil's advocate here but fat tires (4.0 + inches wide) would soften the landing somewhat depending on the tire, air pressure etc...
Commuter/Street Build viewtopic.php?f=6&t=98286:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
Samsung 40T 14S7P
Offroad Build viewtopic.php?f=6&t=102195:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 36T chain ring then 32T chain ring to 11T-46T Cassette
em3ev 14S5P 30Q or 14S6P 25R pack
Samsung 40T 14S7P
I was looking at the reviews of the fork that are using non-electrified fat bikes, which seem to indicate the fork is capable, but can't take big impacts and flexes a lot, and that's without the additional mass. The performance part of the review starts around 5 minutes in.
https://www.youtube.com/watch?v=lI72pLUqsz0
Well, if we are going into tires, jumping does require 2 ply wire beaded tires. Most of them are in the 2.25 to 3.0 width. Some may be found in 4.0, sure not many. Then, 4.0 tires do require fork width that is making very difficult, if not impossible, to find one suitable for jumping. Fat bike jumping is very likely to require custom mods, unless it is practiced on loose snow slopes where robust and stiff components are not as important.
Current bikes
Street:
Dirt:
Current bikes
Street:
Dirt:
I wouldn't do it with an aluminum frame. As I've seen pedego bikes break at the bottom bracket.
Steel fatbike frames are even worse.
Current bikes
Street:
Dirt:
Current bikes
Street:
Dirt:
Oh I guess the only steel fat bikes are Walmart stuff and not colmoly.
Not necessarily "fat" but to me its plenty fat
https://rsdbikes.com/middlechild-chromoly/
https://cad.rsdbikes.com/product/middle ... -chromoly/
https://cad.rsdbikes.com/product/rs291-chromoly/
https://www.pinkbike.com/buysell/2889561/
https://surlybikes.com/bikes/pugsley
edit
If I had the money, I'd go with Surly, or Surface 604 but then again I don't do much jumping, nor do I care much about the materials used for the frame. I've noticed a few 604's for sale over the past year with the electrics gone, I'd chose that frame to build upon. For jumping, the best bet would be mid drive whether purchased from store or built yourself. I like the looks of the expensive store bought ebikes, Rocky Mountain, Specialized etc but I would know I wouldnt like the wattage power they give out as I'd require more power so then I'd look at the Cyclone Elite Downhill (non boxed triangle).
