Extreme spoke angles with big hub motor wheelbuilds
vulcanears   10 mW
Post by vulcanears » Nov 23 2020 6:56pm
I just built a 27.5" wheel with a voilamart motor and the angle between the spoke nipples and the spokes looks extremely dodgy and I'm concerned that it spokes will fail at that bend point. Is there any way to improve this with this build or my next one?
Would nipple washers improve it?
Thank you very much in advance!
markz   100 GW
Re: Extreme spoke angles with big hub motor wheelbuilds
Post by markz » Nov 23 2020 8:34pm
Your nipple angle doesnt look that bad, I've seen worse wheel builds.
You could use Polyax nipples.
You could drill the rim holes out.
Motorcycle and moped rims have angled nipple holes on the rim.
Polyax nipples
https://wheelbuilder.com/sapim-brass-polyax-nipples/
Check out goatmans nipple angle
viewtopic.php?f=3&t=82383&p=1597016&hil ... e#p1596985
More info
viewtopic.php?f=3&t=108540&p=1587897&hi ... e#p1587897
Search list
search.php?keywords=nipple+angle
Chalo   100 GW
Post by Chalo » Nov 23 2020 9:33pm
Those spokes are likely to break at the thread roots, where they exit the nipples. The first step to correct the problem should be to use a drill (same size as the rim holes) to slant the rim holes in the direction of the spokes.
Conical nipple washers might help, but only if the holes in the rim are large enough to allow the nipples to tilt over in line with the spokes. I don't think your grommeted rims will allow that.
I use them to lace 14ga spokes into rims drilled for 12ga spokes.
https://www.jbi.bike/site/product_detai ... mber=56837
ZeroEm   100 kW
Post by ZeroEm » Nov 24 2020 6:01am
Looks like mine but my wheel is 26", so it is worse. The good news as long as the spokes are tight you should not have any problems. I run over 2.5kw up to 35mph no issues.
abundans cautela non nocet
2019 Performer E-Trike 9w/km
2013 Nissan Leaf S 7 bars 331.5w/KM
MadRhino   100 GW
Post by MadRhino » Nov 24 2020 10:30am
That is exactly what we don’t want. To build a good wheel you need both, drilling the rim AND adapting nipple angle, either with the use of Polyax nipples and/or nipple washers. If your rim was smaller, a 24’’ for an example, spokes would start breaking in the first 500 miles even without any hard hit. Your 27.5 may last because the spoke angle is not that bad and quality SS spokes (if so) can take it pretty long, but it won’t stand any abuse.
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
ZeroEm   100 kW
Post by ZeroEm » Nov 24 2020 11:41am
It bothers me but have not had a problem, not all are bent one out of four. but will do it different, like the nipple washers.
999zip999   100 GW
Post by 999zip999 » Nov 24 2020 3:30pm
Nipple washers you have your nipples pierced ?
I worry more about putting brass washers on the heads by the motor end and take the slack out of there on that volimart motor. Next time. My spokes break at the head. 4to 1. Yes I break spokes and smoke motors. Bad habits.
TommyCat   1 kW
Post by TommyCat » Nov 25 2020 5:25pm
I use the same size wheel with a no-cross pattern. No spoke problems in 2 years, and I forged my own... :shock:
Forging shown here at post #13... not that I'm recommending it to anybody. :wink:
https://electricbike.com/forum/forum/bu ... #post51586
Regards,
T.C.
See my completed Magic Pie V5 rear hub E-Bike build Here!
MadRhino   100 GW
Post by MadRhino » Nov 25 2020 6:13pm
TommyCat wrote:
Nov 25 2020 5:25pm
I use the same size wheel with a no-cross pattern. No spoke problems in 2 years...
Low power, smooth surfaces, low mileage... many reasons for this to last, including luck. :roll:
Radial lacing is weak for any hard cornering and rough terrain. Some have no choice because they are building a large motor in a very small wheel but: Single cross pattern makes a much better wheel.
Current bikes
Street:
Dirt:
Chalo   100 GW
Post by Chalo » Nov 25 2020 9:08pm
MadRhino wrote:
Nov 25 2020 6:13pm
Radial lacing is not weaker than cross-lacing, at all. There are two problems with it. First, it has to wind up to be able to transmit torque (from pedal drive or a disc brake). This repeated movement can cause fretting at the hub holes and spoke elbows, and spoke loosening. Second, the hub flange may not be strong enough to withstand spoke tension straight outward, and a piece of the hub flange can tear out.
So for a rim braked front wheel, with a strong hub that won't tear out, radial lacing is as strong as any other cross pattern. Laterally, it can be stronger, because all the spokes can be laced outside the flange.
Radial lacing a hub motor is a good choice when the hub is large and the rim is small. In that case, there's no good way to cross-lace. Also, wind-up between hub and rim is negligible when the hub radius is large and spokes are short.
My Crystalyte 5305 radially laced in a 20" wheel has been one of the most boringly reliable wheels I've had, under quite heavy use and plenty of miles so far. No broken spokes, no loose spokes, and it runs perfectly true with no follow up since I built it.
serious_sam   10 kW
Post by serious_sam » Nov 25 2020 9:10pm
TommyCat wrote:
Nov 25 2020 5:25pm
Regards,
T.C.
Full points for problem solving, I respect your efforts. Improvise, adapt and overcome.
But that's one area that I would never go diy. Rolling threads is one thing, fine no problem, but reforging the head, no way. Highly stressed. Cyclic loading. Heat treated materials. I'll leave that to the quality control, testing, and consistency of mass production. OTS spokes for me please.
