Hi guys...i was thinking on doing another bike build with another qs205 and doing a simple setup.
Do you think a steel fat bike frame with sufficient torque arms to handle the motor power be possible? If so..the rear dropouts would be too wide for the 155mm qs205 so since its a steel frame, could i perhaps use a threaded rod and nuts to tighten and reduce the width slightly in order to fit the motot?
Thanks!!
Thanks!!
