Hi there, I hope that you all had a good Christmas.
I had a problem with my hub motor kit just stop so I bought one of those ebike testers, and it's pointing towards the controller being the problem. But when I'm testing the motor itself the hall lights flash as they should but randomly the lights marked green, yellow or blue stay on? When I say randomly I mean if I turn the tester off one or more of the appropriate colour lights stay on.
Should I be concerned or if the hall lights flash correctly is the motor OK?
Also with the tester powered of and I spin the wheel the lights also flash as they should
Thank you
Thank you
