Chuckles1
I got a rear hub drive kit, 500W I've yet to install. It came with the different PAS sensors, one for the left and two slightly different versions for the right.
The left one appears to be far simpler to install, and I assume it integrates the two separate parts that the right side versions have.
Is there a functional difference between left and right side sensors?
I wonder why the redundancy in the kit. Are these so quirky that you need back-up? I wonder if I should install both sides so if one fails I could plug in the back-up.
Thoughts?
Thoughts?
