Anyone have any experience with these on an ebike?
https://www.ebay.com/itm/Stop-A-Flat-Puncture-proof-Thorn-resistant-No-flat-Bicycle-Tubes-26-x-1-95/143976471114?epid=691390233&hash=item2185aa9a4a:gvQAAOSwpqFgS~1F
I was originally going to use puncture resistant tires and tubes which adds up quick and can still fail. I'm considering using one of these for at least the wheel with the motor and use any cheap tire. I've heard from reviews online that warn against using them with old tires as they fit loose but with new tires they are really tight. I also hear they have extra friction when peddling but this will be in the rear with a motor so I don't think that will effect me much. I mostly worry as they wear, the wheel will spin inside the tire and I wont go anywhere. I'll use a regular tube and puncture resistant tire on the front as it is easy to repair. These would be better with an air bladder inside to make sure it's tight.
