Page 1 of 1
Just license it as a motorcycle?
Posted: Apr 26 2021 11:17am
by willo
I'm seriously thinking of just licensing my high power bike as a motorcycle. My main use for it is while traveling with my camper, and various states are kinda mental about ebikes.
I mean sure, if I have a 750w low power deal I can use it in general. My bike can easily hit 50mph.
Thoughts?
Examples:
Colorado is ebike friendly, no problem.
Georgia looks like a whole mess and hilton head seems to hate high power bikes.
I'm thinking that the best way to avoid major issues is to just go ahead and drop moto plates on it.
Re: Just license it as a motorcycle?
Posted: Apr 26 2021 11:38am
by neptronix
Your bicycle needs to have a VIN associated with it first... and also be designed up to par with DOT standards.
Good luck, lol.
Posted: Apr 26 2021 11:40am
by speedmd
How does 750w ebike hit 50mph? Down a steep hill?
Posted: Apr 26 2021 3:13pm
by markz
You need to blend in riding an ebike and not go 50mph.
If your in that much of a rush, just buy a motorcycle.
Posted: Apr 26 2021 5:00pm
by LewTwo
speedmd wrote:
Apr 26 2021 11:40am
Bad steering ?
Posted: Apr 26 2021 5:21pm
by markz
speedmd wrote:
Apr 26 2021 11:40am
Big leg muscles pedalling with fast gearing on the bike behind a windbreak.
Look at that crank gear, its massively huge!
Posted: Apr 26 2021 6:26pm
by Dauntless
750w helps him get to a speed where that high gearing can work for him. Hmmmmmm.
Posted: Apr 26 2021 7:27pm
by MadRhino
I believe you’d have a hard time licencing a DIY ebike almost anywhere. It would make it easy if it was built on a moped frame that is licenced already. Anyway, what matters most is how you ride, not the power it has. The police are targeting those who behave illegally.
Posted: Apr 26 2021 7:58pm
by Eastwood
Like mentioned above how do you expect to register something with the DMV if it doesn’t have a Vin number? If you’re trying to go that route sounds like you need to buy a moped or motorcycle and then convert to electric. This is common but it’s not allowed in all states and countries.
Posted: Apr 26 2021 8:42pm
by neptronix
MadRhino wrote:
Apr 26 2021 7:27pm
I so agree with this. I build my bikes to do 45-50mph minimum but only operate them at that speed whenever necessary ( no bike lane or alternate route and it would be dangerous to go slower than traffic ). Otherwise it's 30mph all day for range reasons, and also getting a little exercise.
That's probably why i've never had legal problems. :)
Posted: Apr 27 2021 10:11pm
by willo
neptronix wrote:
Apr 26 2021 11:38am
Good luck, lol.
There are plenty of home built motorcycles out there. I can easily build up a frame from a motorcycle that's legal and easy to title.
Posted: Apr 27 2021 10:12pm
by willo
MadRhino wrote:
Apr 26 2021 7:27pm
Again, this isn't hard. I can easily build a motorcycle based ebike. My real question is what's the best way to be covered legally, especially in states where they hate on ebikes. (South Carolina seems to be crappy about it, for example)
Posted: Apr 27 2021 10:13pm
by willo
neptronix wrote:
Apr 26 2021 8:42pm
MadRhino wrote:
Apr 26 2021 7:27pm
This just feels... judgy and doesn't contribute to my actual question.
Posted: Apr 27 2021 10:14pm
by willo
speedmd wrote:
Apr 26 2021 11:40am
Read it again. My bike is more like 8-12kw. If I had a 750w bike this entire line is a non-issue.
Posted: Apr 27 2021 11:33pm
by Dauntless
I do know in California you can build without a proper VIN and get it registered. Back when 'Popular Mechanix' had all those Build This Car articles people did build and register them, I'm sure most states have a process.
In California you register a motorcycle yearly and insure it. You register a moped ONCE for $15 last time I did it and no insurance. That probably is similar to most states. If I felt the way you do I know what I'd try.
Posted: Apr 28 2021 12:02am
by amberwolf
willo wrote:
Apr 27 2021 10:12pm
If you truly want to be covered legally, you'd have to build a minimum of two separate bikes.
One would be an "actual" motorcycle, with all the requirements of that in every state (each one may be different, so you have to check each one).
Then the other(s) would be an ebike, meeting the requirements of each state, many of which are different, and some of which have much more stringent requirements than others do. It may not be possible to have a single ebike that meets every state's definitions (for those that allow them; for those that don't, you're stuck with the motorcycle). But I don't know offhand of any state left that doesn't have some sort of power limit, or some weight limit that will end up restricting power because a bike that will have the kind of power you want will weigh more than the limit. Arizona used to only limit speed, but now they have a similar 3-class system to california, but with a lower power limit.
Legally, for at least most, probably all, states, a motorcycle is not an ebike, and an ebike is not a motorcycle, and it is very likely that what meets one set of rules will not meet the other set of rules, certainly not in every state.
So, unless you are really set on riding the "same" bike in every state, it's going to be a lot simpler to pick the state you're going to live in, and build a bike (MC or ebike) suited to that state's legal definitions and requirements.
To find out the specifics of what's allowed and/or required, you'll need to check with each specific state; many have their laws online so researching those will be fairly easy. Others you may have to send for physical copies of the current laws, etc. Don't rely on what *others* have published about particular states (they tend to "interpret" the law, and that can leave you in the lurch when it turns out they're wrong or they left stuff out)--go to the actual government websites for the actual laws.
