Guys, I've installed several KT controllers without issue, including an identical install as this one. This one is presenting me with a challenge I'm wondering if anyone else has run across. Using an LCD-3 display, 500w geared hub.
Seems to happen in any PAS level, but not when using the throttle. The "assist" indicator is flashing on and off in time with the surging, as well as the watt meter readings.
PAS sensor was working fine with the original controller. No hint of anything like this going on at that point.
All waterproof connectors, bike has never been wet, and it's only a couple of weeks old.
Scratching my head..... any ideas?
-Al
-Al
