I bought a new Advent X drivetrain and everything bolted up seemingly well to my existing hardware. However it seems my derailleur is pushed pretty far outboard. I have to pretty much loosen the limit screw completely to be able push the derailleur over to the lowest gear position. Note: this is just extending the derailleur and pushing it by hand, as I haven't installed the chain yet.
This is the hanger I currently have. Surly says it's for "Shimano Direct Mount-only derailleur".
However there is an additional hanger *available* (maybe) from Surly that looks like this. It's in line vertically with the rest of the chainstay. It seems a vertical hanger would allow the derailleur to be installed more appropriately (at least closer inboard).
https://surlybikes.com/blog/thru_axles_mds_chips_derailleurs_single_speeds_and_you
Does it seem like the adventx is workable with my current hanger? I've never actually installed a new derailleur from a different brand before so I'm a little skeptical.
