PeteCress
Firmware Versions
860c: 20.1c-22
TSDZ2: 0.20.1
My plan is to extend battery life by mostly charging my LiPo battery (https://www.electrifybike.com/collections/batteries/products/52v-40-amp-14ah-super-shark-e-bike-battery) to only 85%.
"Mostly" bc I have been advised to charge it to 100% every month or so to enable the BMS to balance cells.
Does this make sense so far?
If so The Question: How should I set up the Battery & SOC parms?
Right now, I have them set so that an 85% charge shows up on the 860c display as 100%, but that seems like it would be problematic when I do the occasional 100% charge.
Here's what my parms currently look like:
*Battery
> Max Current: 10
> Low Cutoff: 45.0
> Resistance: 300
> Voltage Est: 54.5
* SOC
> text: SOC %
> Reset at Voltage: 56.6
> Battery Total Wh: 590
> Used Wh: 155.0
> Manual Reset: No
860c: 20.1c-22
TSDZ2: 0.20.1
*Battery
> Max Current: 10
> Low Cutoff: 45.0
> Resistance: 300
> Voltage Est: 54.5
* SOC
> text: SOC %
> Used Wh: 155.0
> Manual Reset: No
