hydrocrust
- Joined
- Aug 10, 2007
- Messages
- 2
I have a 2015 iZip E3 Dash, just burned out second hub motor.
Local bike shop found a NOS replacement motor when first one burned out 1.5 yr ago.
I was told at that time it was one of the last motors available. It worked well until now.
I have a newish (Luna) battery, upgraded brakes, replaced fork, and otherwise bike is great.
It has about 4500 miles on it.
Does anyone know if there is a plug-and-play option for replacing the entire hub motor/rear wheel, maybe with some kind of kit?
This is a Currie electro drive S motor, 500 W, uses a 48 V battery.
I see a lot of kits out there, but not sure if any would fit this bike or could be adapted. I have some modest skill and shop access, but hoping to avoid a major project. I realize I would have to attach the disk brake...not sure about other issues with controller, cadence sensor, etc.
Thank you for your wisdom. Andy
